Map Sensor
Old May 11, 2002 | 09:36 AM
HiGhCaM's Avatar
Default Map Sensor
Does anyone now what the limititaions of the factory map sensor in accuracy in ralation to boost levels. Im told that my sensor on my 99 Si is only accurate to 10lbs> anyone know the truth>?
Old May 11, 2002 | 06:34 PM
Giuseppe's Avatar
Default Re: Map Sensor (HiGhCaM)
edit: my reply was not worth anything.!
[Modified by Giuseppe, 3:41 AM 5/12/2002]
Old May 11, 2002 | 06:40 PM
SEFIxCivic's Avatar
Default Re: Map Sensor (Giuseppe)
a hondata using a stock map sensor can read about 12 psi.
Old May 11, 2002 | 06:51 PM
The_Head's Avatar
Default Re: Map Sensor (SEFI8LOxCivic)
yup, around 11-12 psi.
Old May 11, 2002 | 09:02 PM
98Psi ITR's Avatar
Default Re: Map Sensor (xThexHeadx)
2 bar map , do the math. don't forget atmosphere pressure.
Old May 11, 2002 | 09:48 PM
turbo Si's Avatar
A stock map sensor is said to be good till 12lbs. But you have to look at actual barometric pressure which would be 6psi! So in reality it is good up to 6psi, as I was told.
Good Luck
Old May 11, 2002 | 09:54 PM
quikrpm'z's Avatar
im currently using a map sensor.
Old May 11, 2002 | 09:55 PM
sgT's Avatar
sgT
honda map sensors cant read boost
so theyre good till about 0psi.
stock map sensors CAN see boost.
Stock ECUs CANNOT
Old May 11, 2002 | 09:57 PM
MiraiZ's Avatar
Default Re: Map Sensor (quikrpm)
I think we all are...
Old May 11, 2002 | 10:11 PM
quikrpm'z's Avatar
boredoom (sp?) is a terrible thing.
Old May 11, 2002 | 11:16 PM
B20LS-T's Avatar
New User
Default Re: Map Sensor (turbo Si)
Good Luck
I believe barometric pressure is 14.7 psi, but correct me if im wrong,
Old May 11, 2002 | 11:40 PM
Giuseppe's Avatar
Default Re: Map Sensor (sgT)
Stock ECUs CANNOT
Ah, thanks for clearing that up..
krugozor
Feb 21, 2011 08:38 PM
hatchBK4life
Feb 3, 2010 12:08 PM
SnailedEG
Jan 28, 2010 12:52 PM
yoffer
Jul 30, 2007 03:05 AM
teddy_dc2
Aug 8, 2006 07:51 PM
