Turbo B16A2 map Problem ??
Old Feb 24, 2003 | 10:14 AM
_VTI-R_'s Avatar
Default Turbo B16A2 map Problem ??
y have make may own turbo kit
and now when i run it's turn on the engine ligth
is Map sensor or ECU ??
if i use Missing Link MAP Bypass Valve i will resolve the problem ???
thanks
Old Feb 24, 2003 | 10:33 AM
b16ahybrid's Avatar
Default Re: Turbo B16A2 map Problem ?? (_VTI-R_)
thanks
That was hard to read......
I think your asking how to fix your cel now that your gone turbo.
Yes using the missing link will fix your cel problem, oryou can use some check valves between the map sensor and vacuum, thats what i've done for the last 3 years with no problems....
Old Feb 26, 2003 | 01:01 PM
_VTI-R_'s Avatar
Default Re: Turbo B16A2 map Problem ?? (b16ahybrid)
where i can get that those valves ??
my problem is on map sensor
missing link can resolve that ??
Old Feb 26, 2003 | 01:12 PM
rioninja's Avatar
thanks
What have you done for fuel management?
FMU?
Bigger injectors?
Offer
Mar 1, 2006 09:14 AM
khmboostedeh2
Aug 27, 2004 09:17 AM
intoracing
Aug 21, 2004 03:02 PM
_VTI-R_
Feb 28, 2003 01:27 PM
