Manual vs. Electronic: Boost Controllers
Old May 31, 2005 | 02:23 PM
TurboGS-R's Avatar
Default Manual vs. Electronic: Boost Controllers
What is the difference between manual and an electronic boost controller like the HKS evc5?
I always thought it was only for the "lazy" person.
I heard from someone that because of the difference in the wastegate's response to the boost controller, one could pick up midrange or low end power, which results in a lower quarter mile time. Is this true?
PS: I could care less if the car picks up "extra horsepower", unless it helps my quarter mile time.
Thanks.....
Old May 31, 2005 | 03:33 PM
drift2004's Avatar
Default Re: Manual vs. Electronic: Boost Controllers (TurboGS-R)
manual u need to get of ur car to adjust it, and electric u can stay in ur car and adjust boost
Old May 31, 2005 | 05:05 PM
Cee_mon's Avatar
Default Re: Manual vs. Electronic: Boost Controllers (drift2004)
Most EBC can adjust the timing of the wastegate opening, in return will allow for quick spool times.
On the Greddy Profec B is called the "GAIN" button. Not sure for other EBCs.
Old May 31, 2005 | 06:32 PM
TurboGS-R's Avatar
Default Re: Manual vs. Electronic: Boost Controllers (Cee_mon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cee_mon &raquo;</TD></TR><TR><TD CLASS="quote">Most EBC can adjust the timing of the wastegate opening, in return will allow for quick spool times.
On the Greddy Profec B is called the "GAIN" button. Not sure for other EBCs.</TD></TR></TABLE>
The guy that's telling me this has had the Greddy Profed and the Apexi AVCR and says they're both ****. He said that the HKS is the only decent one.
Old May 31, 2005 | 06:50 PM
Cee_mon's Avatar
Well most posts i have seen so far have the profec b and the apexi unit as top notch.
Just search "EBC" and read some responses from owners
I give the old school profec b a thumbs up.
Old Jun 1, 2005 | 07:09 AM
adseguy's Avatar
The wastegate spring or MBC will start to open the valve as soon as some pressure is built up in the system and fully open (flutter to keep boost) when full boost is reached. An EBC will wait until the very last second to open the wasteagate. The advantage are 2 fold in my mind. One, you WILL gain low boost power and spool up time because all the exhaust gas is directed to the turbo. Secondly if your tires like to spin on higher boost levels then you can do like I will and run lower PSI in first and second gear and click a button to higher boost in 3rd to 5th, so you get maximum traction while keeping your foot planted. This will obviously result in quicker 60ft and quarter mile times, but how quick is a guess. Maybe only .1 maybe up to .7 seconds......anyone?
I say EBC if you have $200 bucks and MBC if you don't have too many traction problems or run only lower boost
Old Jun 4, 2005 | 08:32 PM
PA MATT's Avatar
Default Re: Manual vs. Electronic: Boost Controllers (adseguy)
im not sure if this is true or no, but its my understanding an ebc can elmiinate creeping and spiking. On my greddy 15g when i run 10 psi on my mbc, it likes to creep up a couple psi(nothin major), would an ebc such as greddy profec type s or type a fix this problem? thats the impression i was given and would like to know if there is any truth to it. Sorry to steal your thread turbogsr, but just tryin to get further info between ebc/mbc
Old Jun 4, 2005 | 09:04 PM
specv5150's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drift2004 &raquo;</TD></TR><TR><TD CLASS="quote">manual u need to get of ur car to adjust it, and electric u can stay in ur car and adjust boost</TD></TR></TABLE>
try again
Old Jun 4, 2005 | 09:36 PM
MooreBoost's Avatar
Default Re: Manual vs. Electronic: Boost Controllers (specv5150)
MBC's work, and EBC's sometimes work.
Old Jun 4, 2005 | 10:14 PM
PrettyLude's Avatar
its really a trade off, i had a mbc, it wasn't constant with the boost pressure, when the temperatures get warm, the boost pressure would be off, now i have a sbc-id from blitz, and man, that thing works like a dream
Old Jun 5, 2005 | 01:17 AM
flip1199's Avatar
Default Re: (PrettyLude)
well i guess i'm lazy cuz i love my ebc. it's just so simple. If i want to run 10lbs i push the button to 10lbs, if i want to run 20lbs i push the button to 20. hell a few of the ebc's have features like gear dependent boost, and timed boost.
Old Jun 6, 2005 | 06:54 PM
dimes_prelude's Avatar
hold up check this out
http://cgi.ebay.com/ebaymotors...sting
Old Jun 6, 2005 | 06:55 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Manual vs. Electronic: Boost Controllers (dimes_prelude)
ok... its an aquarium pressure valve that will only increase boost 10psi over the spring rate
Old Jun 6, 2005 | 06:57 PM
alpha's Avatar
I think the question has been answered but I just wanted to add I will never get rid of my Blitz SBC i-D. Well, maybe for an Innovative MSBC-1
Old Jun 6, 2005 | 07:00 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Manual vs. Electronic: Boost Controllers (0x64)
i want the world motorsports or whatever it is... made by chris rado
Old Jun 6, 2005 | 07:07 PM
PrettyLude's Avatar
the world electronics by chris rado is taxing, like 1200 dollars i believe
chrisgottigsr
Dec 18, 2005 05:00 PM
5thGenCivicKid
Mar 26, 2005 11:40 PM
Turbo_Si
Aug 22, 2002 12:40 AM
IgniteTeg
Aug 25, 2001 05:32 AM
Mikex25
Aug 16, 2001 03:44 PM
