Manual Boost Controller
Old May 14, 2006 | 01:03 PM
baPES's Avatar
Default Manual Boost Controller
How do u work it?! I dont know which way lowers or raises boost. If the **** goes down does that riase or lower PSI
Old May 14, 2006 | 01:05 PM
Sketch_hs's Avatar
lol omg
what kind?
Old May 14, 2006 | 01:30 PM
baPES's Avatar
Default Re: (Sketch_hs)
IDk even know it looks super cheap and crappy Lol it has red **** and it has 2 hoses connected to it
Old May 14, 2006 | 01:48 PM
kKdARIAN's Avatar
Vice President/CEO
Default Re: (baPES)
i would not try putting it on your setup untill you figure out which way does what... you could damage you setup..
Old May 14, 2006 | 01:56 PM
baPES's Avatar
Default Re: (kKdARIAN)
it was already on the setup @ 5 psi just wanted to lower untill i got some **** installed
Old May 14, 2006 | 01:59 PM
salesmonkey's Avatar
Default Re: Manual Boost Controller (baPES)
you wont be able to lower it if your wastegate spring is for 5 psi.
Old May 14, 2006 | 03:18 PM
ccivic's Avatar
Default Re: Manual Boost Controller (salesmonkey)
looser = less boost
tighter = more boost.
Old May 14, 2006 | 03:20 PM
Soccerking3000's Avatar
Default Re: Manual Boost Controller (ccivic)
just remove it and run the wastegate pressure...
Old May 14, 2006 | 05:13 PM
baPES's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccivic &raquo;</TD></TR><TR><TD CLASS="quote">looser = less boost
tighter = more boost.</TD></TR></TABLE>
thanks
Old May 14, 2006 | 06:11 PM
Mag00n's Avatar
i fear for your motor
Old May 14, 2006 | 07:14 PM
Default Re: Manual Boost Controller (Macan00n)
yea this has bad written all over it
rickturboteg
Aug 28, 2006 05:36 PM
CRAZYHONDA
Feb 27, 2005 03:46 PM
xxscaxx
Feb 21, 2005 04:13 AM
Meet07
Feb 3, 2004 10:45 PM
SIK IN DA HED
Sep 13, 2001 03:16 AM
