Manifold/ Turbo compatibility
Old Mar 24, 2004 | 02:32 PM
Crackerballer's Avatar
Default Manifold/ Turbo compatibility
Hi guys, I am going to begin piecing together my turbo kit this summer, and I am gonna go custom. I have a few questions
Are all precision turbos 5 bolt? Of so, then they cannot bolt up to a revhard/drag log manifold can they?
Will the drag/revhard manifold for a t3 fit a t3/t4, I always thoguht they would, but someone said no, I told them they were wrong.
What is a good spec T3/T4 for a GSR, 99, Looking for good mid range, very streetable, run about 7 or 8 psi on stock internals, get close to 300hp, but alot of usable power, aka good spool.
Thanks for the info guys.
Old Mar 24, 2004 | 05:27 PM
anyone?
Old Mar 24, 2004 | 07:06 PM
TheShodan's Avatar
Moderator
Default Re: Manifold/ Turbo compatibility (Crackerballer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crackerballer &raquo;</TD></TR><TR><TD CLASS="quote">Hi guys, I am going to begin piecing together my turbo kit this summer, and I am gonna go custom. I have a few questions
-The 5 bolt refers to the turbine side of the turbocharger that will hook up to the downpipe. You can use either the 5 bolt or 4 bolt flange pattern when you choose a turbo. I believe that the DRAG Downpipe uses a 5 bolt flange setup, so you should be good to go.
Give me a PM about which turbo charger is right for you. I have a couple of ideas that (based on your goals and preference) might work for you.
LilCivic04
Aug 18, 2005 08:52 AM
dohcMONSTER
Jun 4, 2004 06:15 AM
SPEED123
May 1, 2003 01:11 PM
91cvcsi
Jun 4, 2002 12:33 AM
boosted3g
Oct 24, 2001 12:10 PM
