making a downpipe,radius bend too small?
Old May 18, 2010 | 09:26 AM
90Rexx's Avatar
Default making a downpipe,radius bend too small?
So im going to order my pipes to make my turbo downpipe, and i was going to order a 90 degree pipe with a 3 inch radius bend... im just curious if anyone thinks that may be too tight for optimal exhaust flow? what do most higher end downpipes use for radius bends?
Old May 18, 2010 | 09:36 AM
Blaze45's Avatar
Brrraaaap!
Default Re: making a downpipe,radius bend too small?
I found on one setup I had a 90 deg. bend just off of the exh. housing and I believe it was the cause of my irregularly high exhaust temperatures. It was 3in in dia. If possible, in my opinion avoid using a 90 deg bend.
Cheers,
Blaze
Old May 18, 2010 | 09:39 AM
90Rexx's Avatar
due to my setup a 90 degree bend is necessary, im more worried about restricted exhaust due to how sharp the pipe bends down...
Old May 18, 2010 | 02:27 PM
90blackcrx's Avatar
Won't really matter, yeah you might see a small difference but nothing to cry over.
Dunc
Dec 21, 2015 12:01 PM
b18cya94
Welding / Fabrication
24
Mar 26, 2013 05:41 AM
994TurboCoupe
Jan 13, 2006 10:19 AM
DMax013
10
Feb 18, 2005 10:18 PM
BlueSi2k
Jul 31, 2002 07:47 PM
