what bends did you guys use for custom dp's?
Old 07-30-2002, 09:29 PM
BlueSi2k's Avatar
Default what bends did you guys use for custom dp's?
I plan to buy the appropriate 3 inch bends and cut them up myself then bring them to a muffler shop to be welded...which bends did you guys use to fabricate your own dowpipes? I was thinking 1 u bend and a 90 deg..heres a quick sketch so you can picture it(dont make fun of it ) the blue line is the dp flange red is part of the u bend and green is the 90 degree...will this work?? any other ideas? pics?
Old 07-30-2002, 09:59 PM
Smashback's Avatar
Default Re: what bends did you guys use for custom dp's? (BlueSi2k)
Yes, typically 1 90 degree and 1 180 degree will do you. You can get the 180 degree with the longer legs so you'll have some straight 3" pipe to work with in connecting your DP to your exhaust.
Old 07-30-2002, 10:49 PM
New User
dbman96's Avatar
Default Re: what bends did you guys use for custom dp's? (mplex2000)
I actually managed with just one 2.5" U-bend, but it was a little out of alignment at the bottom so I had to give it an attitude adjustment with flex pipe. Worked just great though.
Old 07-31-2002, 07:47 PM
johnmay19's Avatar
Default Re: what bends did you guys use for custom dp's? (dbman96)
I just used 2 90's and flex. Just cut and reweld to get everything right.
Urinemachine
Welding / Fabrication
14
04-27-2012 04:41 PM
90Rexx
05-18-2010 02:27 PM
LSVtechnologytur...
08-15-2008 08:41 AM
1SlowSi
18
12-21-2004 11:04 PM
E-Rok
11-03-2002 09:37 PM
Quick Reply: what bends did you guys use for custom dp's?
