LSD (Pulling left)?
Old Nov 27, 2007 | 01:06 PM
007EG's Avatar
Default LSD (Pulling left)?
The trans has a stock LSD. I believe the tranny code is y21. The thing is that when i jump on it (but not hard enough to make the tires break loose) the car pulls to the left pretty hard..almost like it floats to the left. But when I let back off the gas it corrects itself and goes back to the right or center position. But when i really get on it and break the tires loose the car goes straight. Why is the car pulling to the left? Curious what your thoughts are and why it pulls to the left. A guy told me that all the cars he has driven with oem LSDs perform like this. Also, the car just had an alignment in july and nothing crazy has happened to it since then. Thanks for any help.
Modified by 007EG at 2:18 PM 11/27/2007
Old Nov 27, 2007 | 01:59 PM
IT'S ME DAVID's Avatar
NooB
Default Re: LSD (Pulling left)? (007EG)
Old Nov 27, 2007 | 02:08 PM
mattssi's Avatar
Nothing about a stock LSD is going to make the car actually pull to one side or the other during load unless it is damaged. I would tend to go with either tread wear on your tires or something along the lines of suspension. Could even be as simple as a blown strut. You should put it up on a rack if you have that ability and check out under the car ?
Old Nov 27, 2007 | 02:46 PM
007EG's Avatar
Default Re: (mattssi)
Kind of what i thought as well. Its weird that its only under acceleration though and not just normally when im driving it. ( I just bought the car). If one shock is adjusted stiffer then the other, could that have anything to do with it? Car was just aligned in july and seems to drive straight otherwise. When the tires spin while really getting on it in first it goes straight, it just happens under acceleration when the tires arent spinning.
Old Nov 27, 2007 | 03:06 PM
rudebwoy's Avatar
when I first installed my new lsd if I accelerated hard it would pull to the until after a while, I think its break in period
Old Nov 27, 2007 | 03:14 PM
flangemastermike's Avatar
what age is the car? condition of the rubber bushes. mine were shot and afer fitting a skunk2 camber kit and adjusting my car drove straight but when i put the foot down the old bushes would twist and make the car pull left until i let off. fitted polly bushes to the front and never had a problem since, just somthing to check.
Old Nov 27, 2007 | 03:17 PM
m R g S r's Avatar
wierd...but before gettin into tearing apart the transmission, check the normal stuff, such as the suspension geometry, make sure no shocks are blown, springs are seated on the shocks correctly, etc etc, go check out the alignment again, and make sure that when the guy (or girl ) is doing the alignment that both sides are the same for toe etc.
Also the easiest thing to check would be the tire pressure, tire wear, make sure both tires are the same (i know its stupid, but hey you may be retarded )
good luck
Old Nov 27, 2007 | 05:45 PM
007EG's Avatar
Default Re: LSD (m R g S r)
passenger side was 5psi lower then the driver side. But wouldnt that make it pull to the right? Guess i'll jack it up and look for anything extremely out of the ordinary.
Old Nov 27, 2007 | 06:11 PM
Muckman's Avatar
Moderator in Chief
Default Re: LSD (007EG)
What car is it? Just bc it has a LSD doesnt mean it has equal length half shafts.
Old Nov 27, 2007 | 07:56 PM
quicksilver1689's Avatar
i ♥ snails
LSD doesnt mean a perfect 50/50 split
Old Nov 28, 2007 | 05:13 AM
007EG's Avatar
Default Re: (quicksilver1689)
93 EG with b-series swap
Old Nov 28, 2007 | 05:48 AM
agrn93ls's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 007EG &raquo;</TD></TR><TR><TD CLASS="quote">The trans has a stock LSD. I believe the tranny code is y21. The thing is that when i jump on it (but not hard enough to make the tires break loose) the car pulls to the left pretty hard..almost like it floats to the left. But when I let back off the gas it corrects itself and goes back to the right or center position. But when i really get on it and break the tires loose the car goes straight. Why is the car pulling to the left? Curious what your thoughts are and why it pulls to the left. A guy told me that all the cars he has driven with oem LSDs perform like this. Also, the car just had an alignment in july and nothing crazy has happened to it since then. Thanks for any help.
Modified by 007EG at 2:18 PM 11/27/2007</TD></TR></TABLE>
This is a common occurance when a car has weak or broken lower a-arm bushings, or radius arm bushings. When you load down the suspension during acceleration and deceleration and it pulls/acts oppositely its because the lower arm is shifting and changing the Caster, Caster setting of the alignment is what causes a pull. So most likely if you change the bushings this will stop.
Unless you have some goofy problem with the torque diffrentiation in your LSD.
Old Nov 28, 2007 | 06:21 AM
007EG's Avatar
Default Re: LSD (agrn93ls)
bump...i'll check it out. Thanks for a great answer
Old Dec 12, 2007 | 04:09 AM
fusebox15's Avatar
What a-arm? you mean control arm? and whats radius arm bushing? is it shock bushing? no such things in parts names, do they have other names?
thanks,
Old Dec 12, 2007 | 06:28 AM
agrn93ls's Avatar
Default Re: LSD (fusebox15)
yes i was refferring to lower control arm. common term in the mechanical business is lower a-arm ( old timer terms that have worn off on me ).
a radius arm is also referred to as a strut rod. its basically the same thing as traction bars. it is a bar that runs from the frame or subframe to the lower control arm to brace it and stop any forward to rearward movement. it is also used to control/adjust caster. caster is the relation of the imaginary vertical line between the upper and lower ball joints, that line and whatever its setting is, is what affects an alignment-caused pull. tires are usually more common to cause a pull than alignment is. unless you have worn out suspension parts, well NM the reason worn out suspension parts cause a pull is because it affects the caster, so all the same.
Old Dec 14, 2007 | 05:22 AM
fusebox15's Avatar
thanks, thats wonderful!
Old Dec 15, 2007 | 04:41 PM
Honda Bull's Avatar
This problem also occurred to me. Not sure what it was. Never got into my suspension to check things out, but if that was the case, then I don't see why the LSD that I installed would do it and an open-diff wouldn't.
I just came to the terms that something was screwed with the OEM LSD, and that was that.
93gsrhatch_1
Transmission & Drivetrain
Feb 23, 2012 10:50 PM
kidwit93delsol
Mar 8, 2008 10:16 PM
91crex
16
Jun 21, 2005 03:16 AM
damnraz
Jun 16, 2005 08:02 PM
bossman032
Jan 31, 2004 07:21 AM
