Horsepower limit of ID1000 & Walbro 450 on E85
Old 06-16-2017, 05:53 PM
Sprockets's Avatar
Default Horsepower limit of ID1000 & Walbro 450 on E85
My car has already been tuned on 93 octane and made 420whp with ID1000 injectors and a Walbro 255 HP. The shop I take my car to suggested that I try E85 for various reasons, and that I need to upgrade my fuel pump to a Walbro 450 if I choose to do so. I understand that cars running E85 use 30% more fuel, and that people generally use larger injectors or higher fuel pressure. However, I found out that the Walbro 450 isn't a high pressure pump like the 255, so I'm concerned that if I stick with the ID1000s I'll lose power on the dyno. The chart I've attached from Injector Dynamics is old and doesn't include the 450, so I don't know what to expect. Has anyone out there used this combo? Are the ID1000s enough to keep me at the same power level?
Old 06-16-2017, 07:02 PM
BADBIDDY's Avatar
Default Re: Horsepower limit of ID1000 & Walbro 450 on E85
i made 434@23psi last year with a Walbro 450 and FIC 1100cc injectors. Can't remember what the duty cycle was at like 85-90%.
Old 06-17-2017, 07:24 AM
Sprockets's Avatar
Thanks, I was looking at FIC. They were suposed to release 1200 and 1400 injectors, but I don't see it on their website.
Old 06-18-2017, 08:35 AM
LightningTeg's Avatar
Check out FIDs (Fuel injector development). I run their 2000's and am at 75%ish duty cycle at stock fuel pressure at 630whp. E85 single Walbro 450.
I maxed out my PTE1000's @ 567whp with the 450 on my old LS setup. Im sure an ID could do a little more.
Old 06-18-2017, 09:38 AM
Sprockets's Avatar
Thanks, I'll check them out. Was the 567whp with E85? I didn't think that would have been possible.
Old 06-19-2017, 02:46 AM
Yeah. Base pressure was at like 65lbs, 32lbs of boost, Injectors were basically stuck open lol
Old 06-19-2017, 08:06 AM
D-Rob's Avatar
I've had ID1000's/Wally450 combo to right around 600hp on E85 a handful of times, but like LightningTeg said, it took lots of base pressure and the injectors were at 100% duty cycle.
What fuel feed/return are you using? What regulator?
Old 06-19-2017, 09:44 AM
GDD Lonely Krew
the_unknown's Avatar
Nothing tech to add but I just wanted to point out that first line of the "Notes" section in that first table...
"Subaru engines take of 5-10%, BSFC is not as good as Honda and Evo engines.."
LOLWUT, PWNED flatbillers....
Old 06-19-2017, 03:00 PM
Sprockets's Avatar
I'm not looking to make that much power, but it's impressive. Sounds kind of risky, though!
That's good to know, thanks. Feed is going to be 6an, and I assume the return will remain stock. The regulator is a version of Aeromotive A1000.
I'm finding two different part numbers for the Walbro 450 after looking up "high pressure" 450. Is there a high pressure version like there is with the 255? One is Walbro 450lph F90000267, and the other is also 450, but F90000274.
Old 06-19-2017, 03:40 PM
sneakypete's Avatar
You will want the F9000267. That is the one that is e85 compatible. The 274 is for gasoline only.
Old 06-19-2017, 08:52 PM
Sprockets's Avatar
That's actually not true. I found this earlier:
"F90000274 = F90000267 with higherpressure relief. E85 compatible.Will support 750+ hp"
http://aftermarket.tiautomotive.com/...01315_VIEW.pdf
Old 06-21-2017, 12:54 PM
D-Rob's Avatar
Sprockets is correct.
The 274 part number is a revision of the 267. It is the ethanol compatible pump but with a higher pressure relief rating.
The 274 is the one you want.
Old 06-23-2017, 08:59 AM
Sprockets's Avatar
Great, thanks. Do you or anyone else know why they even bother keeping the low pressure pump available? Are there any disadvantages to the high pressure, even if you may not technically need it?
Old 06-23-2017, 12:24 PM
2x0
2x0's Avatar
Depending on the relief pressure (mine is like 72psi) I would worry that if the regulator failed and pressure spiked, what else in the fuel system might be damaged by higher pressure. Lines, fittings, filter, etc. unless everything else is also upgraded to handle higher pressures.
Old 07-02-2017, 07:23 AM
th3pwn3r's Avatar
Ages ago, my CRX made 549whp on a Walbro255 and 044 on E85 but duty cycle was near 100% on ID1000s. I'm probably going to jump up to ID2000s and I now have a Walbro450 in the tank and new 044, I burned my old one out.
Edit, I want to say base was in the 60s but can't recall.
Old 07-25-2017, 12:05 PM
porofek's Avatar
For all those that are running E85. Besides the fuel pump and bigger injectors, do you need upgraded fuel lines as well? One of my buddies said my fuel lines will eventually get eaten up so I'd like to do it right the first time before I get a tune for E85.
Old 07-25-2017, 06:03 PM
Moderator
TheShodan's Avatar
Affirmative.
Old 07-25-2017, 07:56 PM
cruizinmax's Avatar
I would say "need" is subjective. Myself and many others have ran e85 for years on stock fuel lines with minimal to no ill effects. I have been on e85 for 5 years now all stock lines. Only swapped fuel pump and injectors. 4 years of that was n/a last year being turboed. When the car was n/a I would get about 320 miles on 10 gallons of 93. On e85 I would get 250ish so it was actually a cost savings over 93. One thing I would be cautious about is the fuel filter. I am using an oem filter and have had no issues but I have seen others break down because of the fuel.
Old 07-25-2017, 09:14 PM
boosted94gsr's Avatar
I plan on upgrading my fuel lines over winter to better handle E85 and I'll be going with a 10 micron fuel filter.
https://m.summitracing.com/parts/fue-81801-1
Old 07-26-2017, 02:37 AM
Im still on the stock lines from tank. Replaced everything in the bay though. Been that way for 5 years now
Old 08-19-2017, 06:04 AM
PROTEC's Avatar
502 ltr/hr @ 50 psi, 6.84 amp draw @ 13.5 vdc
431 ltr/hr @100 psi, 11.92 amp draw @ 13.5 vdc
How many people would be interested in these flow rates. New pump coming out !!!!
Take a look at 50 psi and the amp draw v the Walbro
Take a look at 100 psi compared to the Walbro, the amp draw is a killer.
turbolsvtecej1
09-07-2014 04:06 PM
BroskiZach
04-24-2014 08:01 AM
Mike Lowwryyy
01-25-2012 08:37 AM
turboman2.2
11-30-2010 02:56 PM
turbo-crx
05-21-2009 11:47 AM
Quick Reply: Horsepower limit of ID1000 & Walbro 450 on E85
