LS vtec turbo in process 9:5 vs 9:1 explain the difference on performance and tuning
Old Feb 10, 2004 | 10:25 PM
Rod.'s Avatar
Default 9:5 to high ?
I am deciding which compression I should go with. Some people say 9:5:1 or 9:1. Which one would be better for boost which would keep me running pump gas. I want at least 350-375whp. Also which would be better to tune. This is going to be a ls turbo setup . Still thinking of getting that vtec head also. I have a t3/t4 turbo 50 trim 60 ar just for the records
Modified by redturbocivic at 8:18 AM 2/11/2004
Old Feb 11, 2004 | 07:19 AM
Rod.'s Avatar
Default Re: 9:5 to high ? (redturbocivic)
bump
Old Feb 11, 2004 | 07:28 AM
GaDawgs's Avatar
any time you lower the compression it will be more street reliable under the comsumption of pump gas. 9.5:1 is still a good compression, but 9:1 is lower and would have to run more psi to make the same power. you could find alot of info. through a "search". i've read many arguements on compression on this forum. Basically 9:1 is turbo friendly, used with pump gas, on a daily ,street driven car.
Old Feb 11, 2004 | 07:39 AM
Soon_2b_evil's Avatar
Default Re: (GaDawgs)
run 9.5:1.
Its nice to run 9.0:1 you can run mad boost, but throttle response suxs.
What kinda Fuel Mangment are you running?
If your running a hondata or AEM EMS run the 9.5:1 and just get it tuned.
Old Feb 11, 2004 | 07:51 AM
Rod.'s Avatar
Default Re: (Soon_2b_evil)
i have hondata s200. I dont want to run like 20-25 psi just to get my goal. If i do turn it up to that high i want moooore power.
Suprdave's Avatar
9:1 for a pumpgas motor...
I wanna try 8.5:1 ona Pumpgas motor one of these days...I think it would be worth it.
Old Feb 11, 2004 | 09:27 AM
GaDawgs's Avatar
i agree on 9:1 for pump gas. you generally have more room to play with. i don't know about the throttle response though. but i do know that people make great power with 9:1, 9.5:1, and even 10:1 with proper tunning. it's just i have to drive my car every day so i want to be 100% safe and still be able to turn up the boost and put down some serious numbers.
Old Feb 11, 2004 | 10:05 AM
Rod.'s Avatar
yea, this will be my daily driver. I want more room to improve with.
Old Feb 11, 2004 | 10:12 AM
ChillOutWayne's Avatar
well according to alot of research i did, basically the lower compression ratio will produce slightly less power, but leave more room for tuning and streetability...i just finished my rebuild and now have my CP OS 9:1's in there with OUT boost so far, and to tell u the truth, it doesnt feel all that different compared to the ITR JDM's i had in there before. anyway i went the 9:1 route cause i wanted that extra tuning margin for error, also i wanted to increase the boost level to increase power instead of running the higher comp, and if im not mistaken the lower compression keeps cylinder temps slightly down and pressure on the walls lower. just my two cents.
Old Feb 11, 2004 | 10:37 AM
Rod.'s Avatar
Default Re: (ChillOutWayne)
Thanks, i think i am just going to go with them 9:1 cp's
Old Feb 11, 2004 | 10:57 AM
Suprdave's Avatar
Default Re: (redturbocivic)
I think CP measures their pistons @ 0 deck....so those 9:1s are really in the 8s if you dont deck the block.
Old Feb 11, 2004 | 12:29 PM
LudeToAHatch's Avatar
I would go 10:1 and get it tuned well. Less lag and the same power with less boost.
Old Feb 11, 2004 | 12:40 PM
duckmanEG's Avatar
Sexy Cheese Cake
Default Re: (Suprdave)
yup suprdave that 8.5 would be worth while i know them sr20det are stock with 8.5 cr and they are 2.0 litres
Old Feb 11, 2004 | 03:31 PM
Rod.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">I think CP measures their pistons @ 0 deck....so those 9:1s are really in the 8s if you dont deck the block.</TD></TR></TABLE>
the block will be stepped deck
98tegLSvtec
Mar 8, 2011 04:47 PM
eg:R
Nov 27, 2007 06:15 PM
turboman
Jun 9, 2006 05:11 AM
*Boostwerks*
10
Oct 5, 2004 11:26 PM
intekragsr
May 7, 2003 02:34 PM
