ls v tech turbo e85 setup
Old Aug 31, 2013 | 08:27 AM
mike909's Avatar
Default ls v tech turbo e85 setup
Hey everyone, I am new to this site and im trying to figure out what mods to put on my 99 civic so that I don't have a lot of issues. As of right now I am waiting for my motor to return from the machine shop. My block is a b18a1 sleeved with forged internals (fully built block) and I have some blox racing springs in my si head. I have the walbro fuel pump, blox cast iron manifold, real tial 38mm wastegate, nsx manual boost controller, 58 trim comp turbo and I might be missing something else. I still need to order fuel injectors and a map sensor because im planning on running 15psi. My question is does anyone have any suggestions on which fuel injectors are good that I should buy as well as do I need anything else besides the injectors to reliably run e85?
Old Aug 31, 2013 | 11:03 AM
tyb's Avatar
tyb
Default Re: ls v tech turbo e85 setup
just the injectors and the tune for the e85.
Old Sep 6, 2013 | 10:26 PM
mike909's Avatar
thanks
Old Sep 6, 2013 | 10:29 PM
yungkhmer's Avatar
its vtec. not v tech. vtec valve cover clearly says " VTEC. "
Old Sep 6, 2013 | 11:46 PM
Marvin1985's Avatar
Pics of setup or shenz
Old Sep 7, 2013 | 03:14 AM
jbpnoman's Avatar
How much power are you legitimately expecting out of your setup? Be realistic, and don't lie to yourself - you'll only end up spending more money than you need to.
Use this tool to find a base size, then multiply the number they give you by 1.47 to find out what size injectors you need to use. Be careful picking out your injectors - different injectors are made to flow at different fuel pressures.
Old Sep 7, 2013 | 10:28 AM
wantboost's Avatar
Who is Mr Robot?
What the hell is an nsx boost controller?!?
Old Sep 7, 2013 | 10:30 AM
forryk's Avatar
Buy a set of ID1000cc injectors and a AEM or Aeromotive e85 compatible fuel pump, 320 or 340lph.
I used the walbro 255lph and it wasn't enough for me...
Old Sep 7, 2013 | 11:09 AM
wantboost's Avatar
Who is Mr Robot?
255 won't supply enough fuel at the maximum fuel pressure you'll end up running (base fuel pressure + however many psi you run = maximum fuel pressure)
You need more pump
Old Sep 8, 2013 | 12:46 PM
th3pwn3r's Avatar
You need more pump
Yup, I have a 255 and a Bosch pump under the hood. Everything was basically maxed out when it made 549(?)hp/430 ftlbs. Had to dial it back to 19 pounds of boost.
jdmnic91
Aug 18, 2010 03:23 AM
Afrothunder_72
May 11, 2008 06:06 PM
Got Milk
Mar 16, 2006 12:27 PM
96dcek
Aug 24, 2004 05:48 PM
D-SPEED
Jul 27, 2001 06:16 PM
