ls turbo smoking
Old Mar 29, 2004 | 07:28 AM
turbo89civicb18hatch's Avatar
Default ls turbo smoking
i have an ls turbo t3-60, i have stock injectors and a jackson racing fmu for fuel, the car smokes alot when ur wide open throttle and at idle. it is a blue white smoke. is it my rings valve seals, is my motor blown.
Old Mar 29, 2004 | 09:18 AM
TeamCracka's Avatar
Default Re: ls turbo smoking (turbo89civicb18hatch)
Is the turbo new? If the seals go in the turbo, you'll get a ton of smoke.
Do a compression test and if possible a leak down test and post the numbers here. That'll help in determining if your rings/ring lands are bad or if your valve seals are shot.
spoon93
Apr 1, 2011 09:13 AM
hatchBK4life
18
May 6, 2010 06:36 PM
mpf90
Mar 23, 2009 08:29 AM
2.2EL
Oct 27, 2004 10:46 PM
Hondadrvr215
Oct 15, 2004 10:05 AM
