Lots of smoke!!
Old Mar 11, 2009 | 07:00 AM
mpf90's Avatar
Default Lots of smoke!!
OK, so I've been searching the $#!+ out of this topic and every thread says the same thing, and its not helping alot. I recently put a td05h turbo on my 89 crx with a built ls and it ran ok for about a day then slowly started smoking more and more(white smoke) now it just pours out like crazy. I rebuilt the turbo, replaced the hg and piston rings and it still smokes. The local guy, that everyone goes to, says its the tune. Could it be smoking like that from too rich or lean(if its too rich wouldn't it be black??)? I was thinking mabey valve guides, but supposedly the motor had under 50k on the rebuild, or the turbo is cracked somewhere internally? Im sick of dealing with it i want my car back. Any thoughts/suggestions would me much appreciated.
Old Mar 11, 2009 | 07:53 AM
marcj's Avatar
Default Re: Lots of smoke!!
first off run it without the turbo, if it still smokes check your valve stem seals, then replace your pistons rings.
does it still have the same compression across the cylinders?
Old Mar 11, 2009 | 08:09 AM
mpf90's Avatar
yeah...its been a while since ive worked on it cuse of winter. I cant remember the numbers exactly but they were all within 5psi of eachother.
I wanted to do a leakdown test. I went to orileys and advanced auto to see if they had any, Advanced didn't know what it was and once i explained it said they didnt, at Orileys me and another customer were trying to explain it. Once the guy understood he handed me a compression tester haha.
Old Mar 11, 2009 | 08:28 AM
4drEF's Avatar
Keyboard Humorist
http://www.harborfreight.com/cpi/cta...emnumber=94190
Old Mar 11, 2009 | 11:44 AM
b20beast83's Avatar
someone told me these leak!
dont know the truth
Old Mar 11, 2009 | 11:45 AM
Peeonu25's Avatar
dont know the truth
if it leaks HF will replace it.
Old Mar 11, 2009 | 01:09 PM
4drEF's Avatar
Keyboard Humorist
For $30 and the limited use it will see... Buy 10 of them!
-OR-
Buy just one of these for $299.
http://buy1.snapon.com/products/diag...s/eepv309a.asp
Old Mar 11, 2009 | 01:12 PM
Peeonu25's Avatar
-OR-
thats what i got in the garage... or at least my dad does... i havnt been to my own apartment in 3 weeks cuz ive been working on my car... i just cant go back to using my craftman after using snap on... i think im gonna move back in just to use the tools.
Old Mar 11, 2009 | 01:21 PM
Top Ramen's Avatar
White smoke = coolant
Blue smoke = oil
Black smoke = rich
Old Mar 11, 2009 | 01:29 PM
Ls_dx's Avatar
h.g.?
Old Mar 11, 2009 | 06:53 PM
mpf90's Avatar
Originally Posted by Ls_dx
h.g.?
Theres the problem thats driving me crazy, its a brand new h.g...the old one was ok too..and the fluids arent mixing. I drove it for a bit and no oil in the coolant and the oil wasnt milky or anything.
Old Mar 11, 2009 | 06:58 PM
2000em1si's Avatar
my car runs rich and i get white-ish smoke but it doesnt pour out of it
Old Mar 13, 2009 | 10:07 AM
4drEF's Avatar
Keyboard Humorist
Can it be that maybe the head surface or the block surface is warped. Maybe it is allowing water to leak into the combustion chamber, but not into the oil path.
If that is possible, then with the engine running and smoking, then you should be able to see bubbles of air while inspecting the water in the radaitor.
I've had somethign similar happen - not sure if I had oil in the coolant, but there was a definite leak path from cylinder to water.
With the radiator cap off I could rev the engine and water would shoot out like a gyser.
Old Mar 21, 2009 | 10:28 AM
smoovy's Avatar
I've been having the same problem. I found that when I removed my downpipe, the turbo was leaking into the downpipe. after a HG change, head resurfaced and pressure checked, O-rings replaced, and now I'm pissed because I paid a company to rebuild it for me 2 weeks ago, and now it smokes and leaks like crazy. pretty pissed considering I was supposed to get it tuned today.
Old Mar 23, 2009 | 07:16 AM
mpf90's Avatar
I checked the head and block they aren't warped.
Im gonna try putting in a restrictor in the oil line, hopefully thats it....
Old Mar 23, 2009 | 08:29 AM
nytosc's Avatar
From: New York in the summer, South Carolina in the winter
Post a picture of your oil return line.
oranginal
Jul 3, 2009 11:37 AM
Scheizty
Feb 18, 2009 03:21 PM
crispydee
Mar 24, 2005 10:46 AM
turbo89civicb18hatch
Mar 29, 2004 09:18 AM
Cyber ITR
Aug 6, 2002 03:17 AM
