Ls turbo smokes!!!!
Old Apr 1, 2011 | 07:21 AM
spoon93's Avatar
Default Ls turbo smokes!!!!
Ok so I have a stock ls turbo. Tuned on hondata s100, the problem I's when I get into boost and let off the pedal it's caughs out a cloud of white/blue smoke, when I start the car and it sits at idle it's fine no smoke. Also smells like fuel pretty bad, any ideas guys? The fuel could be because it was 95 out yesterday when I drove it probly was running pig rich but not sure
Old Apr 1, 2011 | 07:24 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: Ls turbo smokes!!!!
thats oil...
could be rings, valvestem seals, or the turbo
Old Apr 1, 2011 | 07:42 AM
spoon93's Avatar
Ya that the things I was thinken the turbo was rebuilt has less then 500 miles on It. Could this possibly have anything to do with a catch can that had jus been installed maybe not correct by chance?
Old Apr 1, 2011 | 07:46 AM
wantboost's Avatar
Who is Mr Robot?
no, that wont cause the problem...
most oil leaks on the intake side wont cause smoke, since they would be burnt during the combustion process... unless they are really bad then you'd see an issue with the car when running.
exhaust side valvestem seals, or the turbine seal... its more than likely the turbo.
What turbo is it>
Old Apr 1, 2011 | 07:52 AM
spoon93's Avatar
It's a turbonetics t3t4 60 trim it was jus recently rebuilt though. I guess I should first check for shaft play huh?And the motor I's bone stock as well been boosted for 3yrs now so it may be on its way out
Old Apr 1, 2011 | 07:53 AM
wantboost's Avatar
Who is Mr Robot?
dont have to have shaft play for a seal to let go
Old Apr 1, 2011 | 07:57 AM
spoon93's Avatar
Oh ok so wat do you think should be the first route? Thanks bro I appreciate ur advise
Old Apr 1, 2011 | 08:00 AM
wantboost's Avatar
Who is Mr Robot?
pull the downpipe off, check the turbine housing and downpipe for oil.. also pull the hot pipe off and check for oil residue
Old Apr 1, 2011 | 08:02 AM
spoon93's Avatar
Ok thanks bro
Old Apr 1, 2011 | 08:03 AM
wantboost's Avatar
Who is Mr Robot?
I would also suggest a compression and leak down test, that will let you see just how healthy your motor is. but it sounds to me to be turbo related, so what I suggested is the quick route
Old Apr 1, 2011 | 08:08 AM
spoon93's Avatar
Lol ya it's actually a pain in my car cause there's no room it's a ef lol but I'll do that
Old Apr 1, 2011 | 08:09 AM
spoon93's Avatar
I did a comp test it was kinda lol all wer 155 one was 140
Old Apr 1, 2011 | 09:13 AM
DaFredsta's Avatar
If it had anything to do with the catchcan it would smoke at idle, my buddy had that problem the filter was clogged and increased back pressure which allowed it to smoke, i would have to think its rings since the compression is low should be around 180-200 just my 2cents...
ChrisCrankz96
May 3, 2013 06:34 AM
WhoGunz517
Sep 16, 2010 08:42 PM
CRXdan
Sep 26, 2005 01:58 PM
B18PoweredCivic
Nov 13, 2002 04:37 PM
inline976
Aug 30, 2002 01:43 PM
