idle!!!
Old Jun 20, 2002 | 09:49 PM
vti-R's Avatar
Default idle!!!
just want to ask to make sure if its ok/safe to idle at 900 - 950 rpm at normal operating temperature...mine is currently idling at that high...
thanks
Old Jun 20, 2002 | 09:53 PM
B-series Assassin's Avatar
Default Re: idle!!! (vti-R)
That seems a tad too high but I wouldn't worry about it. At least it's not idling dangerously low, like some people have problems with.
Old Jun 20, 2002 | 10:23 PM
Ri5e's Avatar
Default Re: idle!!! (B-series Assassin)
750 +- 50 is normal. 900 is a tad bit high...
Old Jun 21, 2002 | 12:29 AM
iH8RICERZ's Avatar
i agree..too high!
Old Jun 21, 2002 | 02:34 AM
ragejed's Avatar
Default Re: idle!!! (BustAhNutZ101)
after I drive around...mine idles at 500 or 400
this ok?
Old Jun 21, 2002 | 10:05 AM
jetdriven's Avatar
Default Re: idle!!! (ragejed)
check your cam timing. my exhaust cam was off 1 tooth causing low idle and almost no idle vacuum.
Old Jun 21, 2002 | 10:46 AM
GSxRated's Avatar
Default Re: idle!!! (jetdriven)
Holy crap batman, I'm idling close to 950. I better get that checked out. Is it normal to idle at 1500 right when you start the car for a minute or so?
Old Jun 21, 2002 | 11:21 AM
Shft@9GSR's Avatar
Default Re: idle!!! (GSxRated)
Fast idle for cold start. then slows down to normal idle as engine warms up.
Sounds pretty normal to me. On OBDI Fast Idle thermal valve on TB. OBDII uses a different method for the same effect.
But sounds normal in my opinion.
Old Jun 21, 2002 | 02:07 PM
IC x Prince's Avatar
New User
Default Re: idle!!! (Shft@9GSR)
sometimes mines drops past the first line...how do I check for this stuff...also I need to check ignition timing
Old Jun 21, 2002 | 06:12 PM
vti-R's Avatar
thats about where mine is idling right now. guess i have to check it out too.
Old Jun 21, 2002 | 07:30 PM
satintegra's Avatar
mine idles at around 700 at normal temp.
it's idles higher during start up and gradually drops.
Old Jun 21, 2002 | 08:01 PM
SlowazzGSR's Avatar
Default Re: idle!!! (satintegra)
Yes your idle is way high......You can adjust idle by loosening or tightening the throttle cable!! 700-850 is about where u wanna be.....I guess its rough to tell with a stock tach, praise god for VAFC!!
92_JDM
Engine Management and Tuning
Aug 12, 2010 03:23 PM
Cuong-nutz
Nov 25, 2004 10:34 AM
Civic Racer X 7
Jul 23, 2003 07:19 AM
sporkcrx
Oct 22, 2002 04:13 AM
