Ls Rods in gsr???
Old 02-20-2008, 08:20 AM
grand champ's Avatar
Default Ls Rods in gsr???
Hey guys, i was in the process of building an ls vtec for boost. Im waiting for my pistons to come in and in the meantime i happend to come across a gsr block for dirty cheap. So im going to use that. Now i see that eagle has differnt rods for gsr to the ls block. Length is slightly differnt. My question is, Can i use the eagle ls rods i already have in the gsr block, or do i have to get the gsr rods??
Thanx guys.
Old 02-20-2008, 08:32 AM
DA_HONDA_BOY's Avatar
Default Re: Ls Rods in gsr??? (grand champ)
yes you can but you have to use the ls crank and ls rods for it to work
Old 02-20-2008, 09:05 AM
So if i use the ls crank and ls rods would this be the same as if i used the gsr crank and gsr rods???
Old 02-20-2008, 09:09 AM
Old Schooler
TOM J's Avatar
Default Re: (grand champ)
Yes it will work LS rods and LS crank you can use the same pistons but now the comp will be slightly higher. Let me know what pistons you have and I may be able to calculate the comp for you.
Tom J
Old 02-20-2008, 09:19 AM
arias part # 3320202
Old 02-20-2008, 09:43 AM
HYBRDcrx's Avatar
so the GSR and LS pistons are the same?? or did I read the post wrong
Old 02-20-2008, 10:10 AM
carzntune's Avatar
Default Re: Ls Rods in gsr??? (HYBRDcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HYBRDcrx &raquo;</TD></TR><TR><TD CLASS="quote">so the GSR and LS pistons are the same?? or did I read the post wrong</TD></TR></TABLE>
They are not the same. In what aspects do you mean? Compression, valve reliefs, etc??
dirtyharryhatch
10
07-21-2009 02:43 PM
SoOHiGH
05-29-2005 10:15 PM
TurboEH2
04-02-2005 11:15 AM
svmnredracr
09-28-2004 07:46 AM
Quicky
11-25-2002 05:12 PM
Quick Reply: Ls Rods in gsr???
