Ls Rods in gsr???
Old Feb 20, 2008 | 08:20 AM
grand champ's Avatar
Default Ls Rods in gsr???
Hey guys, i was in the process of building an ls vtec for boost. Im waiting for my pistons to come in and in the meantime i happend to come across a gsr block for dirty cheap. So im going to use that. Now i see that eagle has differnt rods for gsr to the ls block. Length is slightly differnt. My question is, Can i use the eagle ls rods i already have in the gsr block, or do i have to get the gsr rods??
Thanx guys.
Old Feb 20, 2008 | 08:32 AM
DA_HONDA_BOY's Avatar
Default Re: Ls Rods in gsr??? (grand champ)
yes you can but you have to use the ls crank and ls rods for it to work
Old Feb 20, 2008 | 09:05 AM
So if i use the ls crank and ls rods would this be the same as if i used the gsr crank and gsr rods???
Old Feb 20, 2008 | 09:09 AM
TOM J's Avatar
Old Schooler
Default Re: (grand champ)
Yes it will work LS rods and LS crank you can use the same pistons but now the comp will be slightly higher. Let me know what pistons you have and I may be able to calculate the comp for you.
Tom J
Old Feb 20, 2008 | 09:19 AM
arias part # 3320202
Old Feb 20, 2008 | 09:43 AM
HYBRDcrx's Avatar
so the GSR and LS pistons are the same?? or did I read the post wrong
Old Feb 20, 2008 | 10:10 AM
carzntune's Avatar
Default Re: Ls Rods in gsr??? (HYBRDcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HYBRDcrx &raquo;</TD></TR><TR><TD CLASS="quote">so the GSR and LS pistons are the same?? or did I read the post wrong</TD></TR></TABLE>
They are not the same. In what aspects do you mean? Compression, valve reliefs, etc??
dirtyharryhatch
10
Jul 21, 2009 02:43 PM
SoOHiGH
May 29, 2005 10:15 PM
TurboEH2
Apr 2, 2005 11:15 AM
svmnredracr
Sep 28, 2004 07:46 AM
Quicky
Nov 25, 2002 05:12 PM
