LS nitrous weakess
Old Mar 4, 2006 | 08:44 PM
dahoopdahup's Avatar
Default LS nitrous weakess
Im loking in to building an LS vtec motor and putting a 200 shot if nitrous in it. My question is what are the big weaknesses on an LS motor? I all ready plan on running h beams and a stud girdle. Maybe sleave the block??? If im gonna run nitrous I might as well go big. This will acually be my first import motor im building. I have only built domestics im the past, Im impressed with the quality of stock Honda parts they can take quite a bit of abuse.
Old Mar 5, 2006 | 05:07 AM
sc4dr's Avatar
Default Re: LS nitrous weakess (dahoopdahup)
CP pistons, and sleeve the block, maybe even get it O-ringed while your at it
Old Mar 5, 2006 | 08:37 AM
LSR-Abuser's Avatar
Default Re: LS nitrous weakess (sc4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sc4dr &raquo;</TD></TR><TR><TD CLASS="quote">CP pistons, and sleeve the block, maybe even get it O-ringed while your at it</TD></TR></TABLE>
Don't o-ring you don't need the o-rings,if your on a budget just use a eagle rod,srp piston and getting the block sleeved is up to you .if it was me i would.i ran 120 with no sleeves but it wasn't 200.
Old Mar 5, 2006 | 08:52 AM
Blind-Fashion's Avatar
Stock sleeves should be ok, as long as its not detonating hard. Gl with the setup and keep us updated!
Old Mar 5, 2006 | 09:30 PM
Should make for a pretty fun street machine. If i detonate on that much juice I might as well kiss my motor and hood good bye, LoL I may have a hard time with traction... maybe a 2 stage set up would be a little smoother???
Old Mar 5, 2006 | 09:53 PM
90 integra's Avatar
good thing you asked this becuase i was just about to ask the same thing. i guess tuning is the key to everything. any suggestions? lmk how your set-up goes. and sorry to ***** your thread.
My set-up
-ls block
-ls crank
-Z10 motorsports main gridle
-eagle rods
-JE pistons 9:1 cr about 10:1 on the ls/vtec w/the head milled.
arp headbolts
stock gsr head milled .20 mm
itb's
direct port (150 shot)
specie
Nov 9, 2006 12:52 PM
dominicanito49
Aug 22, 2006 09:21 PM
NITROUSHONDA
Jun 16, 2005 09:25 AM
