LS or GSR trans?
Old May 7, 2007 | 01:50 PM
Pr0j3ctxH@tchx90's Avatar
Default LS or GSR trans?
I plan on turbo'n an Ls in my EF and i wasn't sure what would be better: to go ahead about order complete Ls swap or just motor then buy GSR trans then part together the rest? thanks
Old May 7, 2007 | 02:48 PM
Default Re: LS or GSR trans? (Pr0j3ctxH@tchx90)
bump for help!
Old May 7, 2007 | 03:22 PM
SD_Lurker's Avatar
HT White Ops
I say GSR trans with LSD FTW!
Old May 7, 2007 | 03:32 PM
MJobe's Avatar
Default Re: LS or GSR trans? (SD_Lurker)
type r trans with 4.75 and LSD
Old May 7, 2007 | 03:35 PM
SD_Lurker's Avatar
HT White Ops
Default Re: LS or GSR trans? (JOBEYYYYY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JOBEYYYYY &raquo;</TD></TR><TR><TD CLASS="quote">type r trans with 4.75 and LSD</TD></TR></TABLE>
GSR or LS kiddo!
Old May 7, 2007 | 03:37 PM
Jockobo's Avatar
i prefer the ls tranny on a ls motor if your only revving to 7000...gearing already seems short on it
Old May 7, 2007 | 03:41 PM
fmfkid250's Avatar
ls, gsr you will have to go to 5th in the 1/4
. at leastwith the ls will you can go at least 115
Old May 7, 2007 | 03:48 PM
slooogsr's Avatar
Default Re: (fmfkid250)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmfkid250 &raquo;</TD></TR><TR><TD CLASS="quote">ls, gsr you will have to go to 5th in the 1/4
. at leastwith the ls will you can go at least 115</TD></TR></TABLE>
Say what?!
Old May 7, 2007 | 04:07 PM
eg:R's Avatar
if your looking to make a lot of power(300+) stick to the ls tranny. if not gsr
Old May 7, 2007 | 04:18 PM
CRX_1.8T's Avatar
Default Re: (slooogsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slooogsr &raquo;</TD></TR><TR><TD CLASS="quote">
Say what?! </TD></TR></TABLE>
The OP is using an LS engine, he won't be able to wind out the rpms as much as with a GSR.
Old May 7, 2007 | 04:49 PM
tony413's Avatar
LS or type-r but here decide for yourself
http://www.fatboyraceworks.com/gears/
Old May 7, 2007 | 06:00 PM
a1320addict's Avatar
Default Re: (tony413)
Put something together that will meet your needs, it's really the best bet.
Old May 7, 2007 | 06:05 PM
Default Re: (a1320addict)
alright thanks for the help....im going to price ITR trannies and see if i can handle that making 5.15 an hour ...lol
HamiltonRex's Avatar
id go with the gsr, i ran the ls on my setup, reving to 8k, was too short, holding me back with my power levels.
Old May 7, 2007 | 07:01 PM
Default Re: (HamiltonRex)
yeah ..GSR sounds good...i've been lookin around and type R tranny is a bit salty...
Old May 7, 2007 | 07:55 PM
slooogsr's Avatar
Default Re: (CRX_1.8T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_1.8T &raquo;</TD></TR><TR><TD CLASS="quote">
The OP is using an LS engine, he won't be able to wind out the rpms as much as with a GSR.</TD></TR></TABLE>
No i understand that but using a gsr trans will put you in 5th gear at the end of the 1/4 mile?
Old May 7, 2007 | 08:06 PM
CRX_1.8T's Avatar
I guess if people are shifting at really low rpms they would end up in 5th by the end of the run, I dunno. I think a lot of people are afraid to rev their non-VTEC engines past 6500 haha. I can't really say because I've just had this same 1990 LS tranny for the last few years, never experienced the GSR's gearing first hand.
Old May 7, 2007 | 08:50 PM
Jockobo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">id go with the gsr, i ran the ls on my setup, reving to 8k, was too short, holding me back with my power levels.</TD></TR></TABLE>
ls tranny has shorter gearing than gsr? that's news to me
Old May 7, 2007 | 09:51 PM
tpod's Avatar
Default Re: (Jockobo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jockobo &raquo;</TD></TR><TR><TD CLASS="quote">
ls tranny has shorter gearing than gsr? that's news to me</TD></TR></TABLE>
lol it doesn't. im rocking ls rite now, at 8k in 3rd it goes damn near 100
Old May 8, 2007 | 03:22 AM
SIXTY-1HATCH's Avatar
Default Re: (tpod)
aight heres the deal
LS TRANS has THE LONGEST gears for b series. The ls trans is realistically the best trans for the ls cuz when you shift it puts you right back in the " sweet spot" of the ls. A type r trans is the same thing as a b16 trans YOU DON"T WANT THAT. The gsr trans is a good debate and NO you WILL NOT go into 5th with a gsr trans or the ls. Put it this way if your plans are low boost not too much power and stock internals use the gsr, it has a little bit faster gearing so with less hp it will make your car faster, but if you plan on boosting and building over 300hp than i would say stick with the ls trans. You gotta remember a vtec trans is not made to **** at 7k you know. My stock ls on 13psi i used my ls trans and loved it, but its up to you i have personally used both and i am currently using my gsr with gsr trans, like i said low boost gsr higher levels ls but either way you look at it that ls trans is MADE for the ls block the way it revs down low with tq.
Old May 8, 2007 | 05:00 AM
hbyrd8701's Avatar
Default Re: (SIXTY-1HATCH)
is the a1 tranny is shorter than the ys1 because somehow my a1 tranny seem short
Old May 8, 2007 | 06:14 AM
tpod's Avatar
Default Re: (hbyrd8701)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hbyrd8701 &raquo;</TD></TR><TR><TD CLASS="quote">is the a1 tranny is shorter than the ys1 because somehow my a1 tranny seem short </TD></TR></TABLE>
i dont think so, my a1 is longer than my s1
Old May 8, 2007 | 06:26 AM
tony413's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIXTY-1HATCH &raquo;</TD></TR><TR><TD CLASS="quote">aight heres the deal
LS TRANS has THE LONGEST gears for b series. The ls trans is realistically the best trans for the ls cuz when you shift it puts you right back in the " sweet spot" of the ls. A type r trans is the same thing as a b16 trans YOU DON"T WANT THAT. The gsr trans is a good debate and NO you WILL NOT go into 5th with a gsr trans or the ls. Put it this way if your plans are low boost not too much power and stock internals use the gsr, it has a little bit faster gearing so with less hp it will make your car faster, but if you plan on boosting and building over 300hp than i would say stick with the ls trans. You gotta remember a vtec trans is not made to **** at 7k you know. My stock ls on 13psi i used my ls trans and loved it, but its up to you i have personally used both and i am currently using my gsr with gsr trans, like i said low boost gsr higher levels ls but either way you look at it that ls trans is MADE for the ls block the way it revs down low with tq.</TD></TR></TABLE>
honestly it depends on the purpose of the car if its DD the ls or Y1 trannies are fine if its gonna be a strictly race car the S4C and S80 are the way the go. or if you want a more personal feel build an ls with it 1-3 gears an then put in type-r 4-5 gears. the main goal is to get traction an put power to the wheels.
Old May 8, 2007 | 07:08 AM
sp00led's Avatar
Yea, LS is cool for daily driver. 5th gear is nice for cruising where a gsr at 90mph is damn near 5k rpm. If your not big on interstate cruising get the gsr. It will be best for racing around town. Also save your money for an lsd. That was like night and day for torque steer.
Old May 8, 2007 | 07:46 AM
crxsir23's Avatar
Default Re: (sp00led)
i asked the same question a long time a go never going to get a strait answer but the Margarette of the racers iv talked to are running short gears just met a guy last week in he had a ls engine and a gsr tranny turbo running 10:17 or something like that I'm running the s4c love it I'm going in to 5th wright now but ones i get mine to tern more rpm it well pay off
