ls boost setup
Old Apr 25, 2013 | 09:53 AM
maltman111's Avatar
Default ls boost setup
ok so i know that thier is million threads about boosting the ls engine. But i want to know what the engine can handle(and for how long) on bone stock internals. I want to get the ls swap and run it na for a month or two till i get the parts & money for a turbo,but i dont want to upgrade the internals. i have a poor mans gsr that is currently in my 98 civic coupe but it isnt running nd i need a dd right now. so i want to but the ls swap in nd have as much fun with it bone stock as possible.
also my hp goals im hoping for 250-275whp. nothing crazy just fun for the summer.
Old Apr 25, 2013 | 10:00 AM
Schister66's Avatar
Man U FTW
Default Re: ls boost setup
You already know there are a million threads about boosting the LS...then why aren't you able to find your answer out there amongst these other threads? I know this has been covered in detail 1000x before.
Your goals of 250-275whp are fine and as long as you build a quality setup, have reasonable goals, tune it professionally, and regularly service the engine, you shouldn't have any issues with longevity. Problems arise from over-stressing parts, but more often from laziness and bad maintenance
Old Apr 25, 2013 | 10:08 AM
rich7777's Avatar
https://honda-tech.com/forums/forced-induction-16/%2A%2A%2Aforced-induction-forum-faq%2A%2A%2A-1024174/
Old Apr 25, 2013 | 10:19 AM
justYncredible's Avatar
It's wU to the sOLdiEr!
Poor mans gsr?
I know of a poor mans itr
Old Apr 26, 2013 | 08:08 AM
maltman111's Avatar
yeah same meaning different names. its the first gen b16a head.
but i think that im just going to scrape up the money and get a gsr longblock from hmo..they are sold out of the ls engines anyways.
Old Apr 26, 2013 | 10:22 AM
B16 head + gsr block = poor mans itr
Not sure what makes a poor mans gsr
Ls head + gsr block =.....nah that can't work
Old Apr 26, 2013 | 11:09 AM
Schister66's Avatar
Man U FTW
Depending on price, it might be cheaper to find a block locally and rebuild it for boost. You might be surprised how little it can cost if you're willing to put in the time and effort
Old Apr 27, 2013 | 05:01 PM
fandsmachine's Avatar
Boost at 11psi
Old Apr 27, 2013 | 05:10 PM
Originally Posted by fandsmachine
Boost at 11psi
huh?
mod:
does anyone screen these post before theyre made from trial users?
Old Apr 27, 2013 | 05:30 PM
The op asked what a stock ls can handle. I had a bone stock ls prior to my current car. I had the boost set and tuned at 11 psi with no problems. Im not entirely sure what was so mind boggling about my previous post but that is why I said boost at 11 psi.
Old Apr 27, 2013 | 05:31 PM
grumblemarc's Avatar
The Grumpiest
No. They should.
Old Apr 27, 2013 | 05:34 PM
TheShodan's Avatar
Moderator
Old Apr 27, 2013 | 05:52 PM
your entire understanding with boost and whp.
Old Apr 27, 2013 | 06:12 PM
11psi should bring him to his goal. I made 256 whp. What is off about my understanding with boost and whp? explain this to me so I can learn.
Old Apr 27, 2013 | 06:17 PM
psi doesnt translate to whp
11psi doesnt = 150whp
a gt30 on 11psi is different on a gt28rs
real world example:
my setup on 10psi yeilds me 345whp
Old Apr 27, 2013 | 06:42 PM
POPLERO's Avatar
so u mean to tell me more boost dosent mean more power
Old Apr 27, 2013 | 06:50 PM
TheShodan's Avatar
Moderator
No one of any experiences uses that direct correlation like that without knowing what turbocharger is used.
Here's an example.I could take a T25, be at 14psi, and make XXwhp. I turn it up to 17psi, and because of the fact that its efficiency range is maxed at 15psi anyway, increasing boost pressure would not yield more hp. It would just create more heat.
I do the same thing to a GT3076R, and I actually could make more power, but oops!!! I have a crappy intercooler.. More boost can't make more power because the intercooler can't exchange heat properly.
PSI means very little without knowing the turbocharger and efficiency range.
Old Apr 27, 2013 | 07:39 PM
co-sign!
Old Apr 27, 2013 | 09:50 PM
I already knew that different size turbos are going to have different air density due to having a cooler air charge if the size of the turbo is larger because it has less work to do. What I should have said is that 11 psi will bring him to his goal if hes running a gt3076 like I was running.
Old Apr 27, 2013 | 10:03 PM
TheShodan's Avatar
Moderator
Yes. Being clearer would have made your point much more beneficial. Especially if the turbo you using as an example were stated.
I'm sure you'll do better with taking the additional time to type your point with a bit more resolve.
(Yes, I can be an ***, I get that already.. So save your time and keystrokes mentioning it, and Just move on, as now you know for next time.) Oh, and BTW, welcome to Honda-Tech.
Old Apr 27, 2013 | 10:47 PM
Will do from now on and thanks
Old Apr 28, 2013 | 02:13 AM
Turbo-LS's Avatar
why not just get the poormans type whatever running and dont waste money on a different engine ?
Otherwise i can get you a really good deal on a gsr swap. motor has 6500 miles on it since rebuild with all OE parts.
Old Apr 28, 2013 | 12:56 PM
Acaffi92EG's Avatar
Boosting a Stock Ls. I would built thebottom end before throwing boost at it.
Arp head studs, Upgraded crank, Pistons, Rods, and high performance head gasket.
Old Apr 28, 2013 | 01:14 PM
What's wrong with the stock crank and head gasket?
Old Apr 28, 2013 | 01:22 PM
The Grumpiest
He doesn't know. I can guarantee you he doesn't. Sounds like he's parroting something he's heard.
yayizzil
12
Dec 17, 2008 09:10 AM
jtornado
Nov 2, 2006 12:55 PM
S1NFUL RL1 619
Aug 24, 2006 06:38 AM
ITR-T-GUY01
Oct 8, 2005 11:07 AM
jbell
Feb 6, 2004 01:43 PM
