lowest boost to use the VAFC "hack"
Old Mar 14, 2002 | 04:57 AM
willyboyK20's Avatar
Default lowest boost to use the VAFC "hack"
just what the topic says, this would be on the sohc greedy kit with 5.5 psi and no intercooler. I have read the post on this subject but most of the guys doing are running 10 psi. can it work with just 5.5psi? it would save me alot of money headaches.
thanks in advance
[Modified by willyboyD16, 8:57 AM 3/14/2002]
Old Mar 14, 2002 | 04:58 AM
RGAZ's Avatar
New User
Default Re: lowest boost to use the VAFC "hack" (willyboyD16)
Yes. No change to the setup. It will work at any boost under 10.8 psi. After that you run out of MAP.
lower boost isn't usually the problem.
Randy
Old Mar 14, 2002 | 05:43 AM
VTC_CiViC's Avatar
Default Re: lowest boost to use the VAFC "hack" (RGAZ)
Actually, you run out of MAP around 14psi. I've had brief spikes to .85bar w/o a MAP problem at -35% trim.
Hiboost 2.0
Apr 17, 2013 08:14 PM
_Endless_
May 19, 2003 08:33 AM
turboegg
May 2, 2003 04:32 AM
nolimits
Dec 22, 2002 12:13 PM
vtecsiqt
Jun 30, 2002 09:43 PM
