Lowest boost?
Old Aug 31, 2003 | 06:49 PM
chris@allmotor.net's Avatar
Default Lowest boost?
What is the lowest point of boost that you can actually feel or will make a difference on a d16 (CRX Si) motor? and why?
Old Aug 31, 2003 | 07:55 PM
Cruiser G's Avatar
Default Re: Lowest boost? (chris@allmotor.net)
Um, 1 psi will probably make a difference, not very much though.
Old Aug 31, 2003 | 11:20 PM
Drumwurks's Avatar
Default Re: Lowest boost? (Cruiser G)
I ran 3 PSI while i was tuning my setup.
felt the same as running an intake, header/cat/exhaust on the stock D16A6 motor.
(by this I mean, it pulled the same)
Old Sep 1, 2003 | 08:43 AM
Default Re: Lowest boost? (Drumwurks)
anyone? whats the lowest boost you can run with a difference...
Old Sep 1, 2003 | 10:33 AM
Teg4e's Avatar
depends on how well calibrated your butt dyno is. I'd say 1 psi will be kinda noticeable, but 2 psi, somewhat more. 3 psi is definitly noticeable, while 4 will give a nice pull. 5 psi is nice, but not as much as 6. Was this the stupid answer you were looking for?
Old Sep 2, 2003 | 03:40 PM
Default Re: Lowest boost? (Teg4e)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teg4e &raquo;</TD></TR><TR><TD CLASS="quote">depends on how well calibrated your butt dyno is. I'd say 1 psi will be kinda noticeable, but 2 psi, somewhat more. 3 psi is definitly noticeable, while 4 will give a nice pull. 5 psi is nice, but not as much as 6. Was this the stupid answer you were looking for? </TD></TR></TABLE>
no, i was looking for a valid reason and what the actuall lowest boost you can run with before you would actually start gaining.
Old Sep 2, 2003 | 05:05 PM
kpt4321's Avatar
1 psi would probably not be noticable, because it would merely offset the VE losses due to running a more restrictive intake and exhaust path. You probably need 2-3 psi before you actually have a power increase.
Who cares that? A turbo is too big a project to just set the boost at 3 psi. If you have it, use it.
Old Sep 2, 2003 | 10:02 PM
freeplay's Avatar
Default Re: (kpt4321)
Isn't atmoshpheric pressure 1psi? I was pretty sure it is.... am I right? So, the way you guys are talking, 1psi would be equal to 2psi. Now I'm just rambling. I'm tired. ****.
Old Sep 2, 2003 | 10:34 PM
twkdCD595's Avatar
Default Re: (Civic@7psi)
either way whats the point... 4.5- 5.0 psi is almost to low.
you might as well get one of those electric superchargers... they almost push 1psi (maybe).
Old Sep 2, 2003 | 11:05 PM
Kack's Avatar
atmospheric pressure is 13-14 psi. When you put a turbo on ur car, u add more psi on top of atmospheric pressure.
Old Sep 3, 2003 | 06:59 AM
Default Re: (twkdCD595)
well, the reason i was asking is because my friends turbo CRX runs 4.5 psi, and im like well thats like nothing, i was like ya, like 3 PSI is pretty much stock preformance, he was tellin me that any PSI is difference...
Old Sep 3, 2003 | 07:13 AM
quikB18B's Avatar
Default Re: (chris@allmotor.net)
Well look at it like this, when people go and put i/h/e on thier car they say they can feel a difference on the butt dyno(maybe 10 hp), so would you think 1-2 psi would be noticable
Old Sep 3, 2003 | 07:14 AM
kpt4321's Avatar
Atmospheric pressure is 14.6956, commonly approximated by 14.7 psi. If you want to be more general than that, you could call it 15 psi, but why?
When we talk about boost, we are talking about gauge pressure, not absolute pressure. Gauge pressure is the pressure degarding atmospheric as zero.
When you install a turbo, you lose some power because of the higher backpressure and more restrictive intake causing VE losses. You need to add some airflow with boost, in order to get back to where you started.
Old Sep 3, 2003 | 09:34 AM
Teg4e's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic@7psi &raquo;</TD></TR><TR><TD CLASS="quote">Isn't atmoshpheric pressure 1psi? I was pretty sure it is.... am I right? So, the way you guys are talking, 1psi would be equal to 2psi. Now I'm just rambling. I'm tired. ****.</TD></TR></TABLE>
No, go to bed.
Old Sep 3, 2003 | 05:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kpt4321 &raquo;</TD></TR><TR><TD CLASS="quote">Atmospheric pressure is 14.6956, commonly approximated by 14.7 psi. If you want to be more general than that, you could call it 15 psi, but why?
When you install a turbo, you lose some power because of the higher backpressure and more restrictive intake causing VE losses. You need to add some airflow with boost, in order to get back to where you started.</TD></TR></TABLE>
well this is the question i was posing, like what is that psi that you would get the difference?
Old Sep 4, 2003 | 10:32 AM
kpt4321's Avatar
Exactly how much you need will depend on lots of things. I'm thinking something like 3 psi, but who knows. It's definately more than 1.
ochsy03
Nov 4, 2005 07:33 PM
hb_rule_b18
Jun 28, 2005 04:03 AM
TurboEG6
Feb 9, 2004 10:41 AM
sikcrx80
Aug 4, 2003 09:23 AM
TurboSedan
Apr 22, 2002 08:37 PM
