Joe P MBC installed, running 9 psi now
Old 04-22-2002, 05:51 PM
New User
TurboSedan's Avatar
Default Joe P MBC installed, running 9 psi now
I installed the Joe P MBC tonight and set the boost to 9 psi. It was a pain in the *** because I had to keep adjusting it until I found out what was 9 psi, but I finally found it. At first I had a little pinging at 9 psi above 5K rpms. I then retarded the timing a bit and raised the static fuel pressure from 50 psi to 57 psi. The pinging went away! I was so stoked! The car pulls like a deranged psycho demon on crack!
Old 04-22-2002, 06:36 PM
Smashback's Avatar
Default Re: Joe P MBC installed, running 9 psi now (97CivicFerio)
That's why I got the TurboXS HP MBC. I know that one turn on the coarse screw is one PSI! But 9 is lots of fun, huh? I turned mine back down to 8 until I get the WG dumped into the exhaust and get it on the dyno!
Old 04-22-2002, 07:14 PM
New User
SIK IN DA HED's Avatar
Default Re: Joe P MBC installed, running 9 psi now (mplex2000)
with that turboxs hp mbc... is there a beginning boost level? lets say for example... turning it right will adjust the boost. is there a limit to where you can turn it left? i was just wondering how you would know what boost level you were starting off with.
Old 04-22-2002, 08:30 PM
New User
TurboSedan's Avatar
9 psi is a ton of fun! I am still grinning!!!
Old 04-22-2002, 08:37 PM
Smashback's Avatar
Default Re: Joe P MBC installed, running 9 psi now (dlplayboy)
Well, the instructions tell you how to calibrate it. If I remember right, you turned it one way or the other until the mechanism is "snug" (the ball does not rattle when you shake the MBC). That's the scientific part
Doing that put me at like 4.8 PSI, and I am running a Tial with the smallest spring, which I think is like 4.7 PSI or something like that. So, the initial setting got me pretty close to what it would be without the MBC. Then, you turn one full turn counter clockwise on the coarse adjustment screw to turn it up one PSI. Then you can fine tune with the fine adjustment screw if you want.
TurboEG6
02-09-2004 10:41 AM
chris@allmotor.net
09-04-2003 10:32 AM
fastlude69
05-13-2003 07:30 AM
Quick Reply: Joe P MBC installed, running 9 psi now
