Boost PSI Setting
Old Feb 9, 2004 | 08:55 AM
TurboEG6's Avatar
Default Boost PSI Setting
I was wondering if anyone knows how to read the Boost Gauge settings. If 1.0 bar = to how many lbs?
Old Feb 9, 2004 | 08:59 AM
b18bturbo's Avatar
Default Re: Boost PSI Setting (TurboEG6)
its approx 14.7 =1.0bar
Old Feb 9, 2004 | 09:04 AM
TurboEG6's Avatar
Default Re: (b18bturbo)
Is there a chart or something where it'll tell me the other settings as well? .5 bar and so on?
Dancing is Forbidden's Avatar
Default Re: Boost PSI Setting (b18bturbo)
the better question is: What the hell is mm/Hg Damn Rx-7 has it and I never knew what Psi it is. it hits around 40 mm/Hg at full boost.
Old Feb 9, 2004 | 09:06 AM
b18bturbo's Avatar
Default Re: (b18bturbo) (TurboEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboEG6 &raquo;</TD></TR><TR><TD CLASS="quote">Is there a chart or something where it'll tell me the other settings as well? .5 bar and so on?</TD></TR></TABLE>
.25Bar (3.63 psi), .4Bar (5.80 psi), .5Bar (7.25 psi), .6Bar (8.70 psi), .7Bar (10.15 psi), .8Bar (11.60psi), .9Bar (13.05 psi), 1.0Bar (14.50 psi)
1.1Bar (15.95 psi), 1.2Bar (17.40 psi), 1.3Bar (18.85 psi), 1.4Bar (20.30 psi), 1.5Bar (21.75 psi), 1.6Bar (23.20 psi) and up
Old Feb 9, 2004 | 09:11 AM
b18bturbo's Avatar
Default Re: Boost PSI Setting (EF9_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9_SiR &raquo;</TD></TR><TR><TD CLASS="quote">the better question is: What the hell is mm/Hg Damn Rx-7 has it and I never knew what Psi it is. it hits around 40 mm/Hg at full boost.</TD></TR></TABLE>
are you sure its mm/Hg and not in/hg
mm/hg to conver t would only be .7 psi
in/hg to convert to psi would be 19psi
i would think it would be in/hg and not mm/hg
Old Feb 9, 2004 | 09:16 AM
TurboEG6's Avatar
Thanks b18turbo, I appreciate your help!
Old Feb 9, 2004 | 09:18 AM
mrx's Avatar
mrx
pressure in psi * 0,069 = pressure in bar
pressure in bar / 0,069 = pressure in psi
Old Feb 9, 2004 | 09:25 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo &raquo;</TD></TR><TR><TD CLASS="quote">
i would think it would be in/hg and not mm/hg</TD></TR></TABLE>It says 10mmHg. I guess that would be 7 psi.
Old Feb 9, 2004 | 09:40 AM
TeamCracka's Avatar
1 Bar is 14.7psi OR 1in/hg - anyone with a VAFC or AFC should know this.
Going from bar to psi is like middle school math... .5 bar is 14.7 / 2 etc
Old Feb 9, 2004 | 09:48 AM
Farmer Brown's Avatar
10 mmHg is about .2 psi.
1 mmHg is .01933 psi
http://www.onlineconversion.com/pressure.htm
Old Feb 9, 2004 | 10:41 AM
roydogg's Avatar
Default Re: Boost PSI Setting (Djaric)
Boost Conversions
Kg/cm²
<U>Kg/cm²</U> <U>Lb/in² </U>
0.50 7.10
0.55 7.82
0.60 8.53
0.65 9.24
0.70 9.95
0.75 10.66
0.80 11.37
0.85 12.08
0.90 12.79
0.95 13.50
1.00 14.22
1.05 14.93
1.10 15.64
1.15 16.35
1.20 17.06
1.25 17.77
1.30 18.48
1.35 19.19
1.40 19.90
1.45 20.61
1.50 21.33
1 Bar = 14.503774 psi.
1 Kg/cm² = 14.223343 psi.
1 Atmosphere = 14.695949 psi.
Modified by roydogg at 2:56 PM 2/9/2004
BoOsTiN Dc2
Aug 6, 2005 09:55 PM
crxzcracer
Jun 15, 2005 04:56 PM
chris@allmotor.net
Sep 4, 2003 10:32 AM
fastlude69
May 13, 2003 07:30 AM
