lower boost level below stock 14b
I was woundering if there is away to lower the stock boost setting on a 14b below stock, could i use a different actuator if so what one or is there an addjustable actuator i could on the 14b.is there away to change out the sprinf for a lower setting one
thanks
thanks
i'd like to lower the boost on my internally wastegated td05h-18g. the actuator arm is long as possible already. i need a weaker spring i believe. or an actuator assembly with a weaker spring. they dont look like you can take em apart and swap the spring like a Tial.
tzsir, that way i could use the boost control solenoid. i'd like to roll off boost near redline for testing/ safety reasons.
TurboDANDEE
Nov 16, 2003 12:31 PM
