GReddy Profec B... How Much Boost Can It Control?
Just wondering how high can it controll boost? I know it depends on the WG spring, but how high can it go on top of that? Right now, im running a Tial 46mm WG with a 10lb. spring and i cant seem to boost passed 17-18 psi? I've tried replacing my vacuum lines and tried different installation set-up, but still wont go passed 17-18 psi. Last resort i got is to up the spring to a 15 lb. but i dont want to do that right now, anyone got a solution?
Re: GReddy Profec B... How Much Boost Can It Control? (TurboDANDEE)
i think u have ur spring pretty much maxxed out, u can usually effectively double the rating of ur spring..but ur close
mike
mike
Re: (TurboDANDEE)
I saw somewhere that you can use an external pressure source with the innovative boost controller. I would think this would let you boost as much as you want to on any size spring. Check it out:
http://www.nlrsystems.com/pages/boost_con.html
Re: (Foozball26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Foozball26 »</TD></TR><TR><TD CLASS="quote">it can control 14 lbs over the wastegate spring.</TD></TR></TABLE>
Is that with or with out an external pressure source?
Re: (TrueNorthStar)
thats just with the profec unit itself.
using an external source you could feasibly keep the wastegate closed no matter the boost level.
Re: (Foozball26)
it will boost around 30 pounds if hooked up correctly. i have a 9 pound spring and at the 1:00 o'clock position i am at 23 pounds
Re: (speedworks)
yea i think it depends on how its hookedup, ive been trying to get answers on this for a while. i was told when i had my 6psi spring it would top out at like 18-20 psi.. ..soi stepped up to 10psi spring on the new WG , hoping i can get at least like 26 psi from it.
i dont wanna have to run 1bar every day if i dont want to. i know when setting up my spec 2 when the desired boost level is too close to the spring rate its a bitch becuase theres nothing really to adjust. of room to fine tune.
Re: (Evil DOHC)
Im running a 8 psi spring and the greddy profec b spec 2. At 55% it boosted 20psi on my setup. I havent tried to go any higher than that yet.
Re: (speedworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedworks »</TD></TR><TR><TD CLASS="quote">it will boost around 30 pounds if hooked up correctly. i have a 9 pound spring and at the 1:00 o'clock position i am at 23 pounds</TD></TR></TABLE>
can u tell me what im doing wrong or tell me how to hook it up right?
well since im running a 10 lb. spring and the profec can control 14 lb. + standard spring, that means around 24 psi. then how come i cant pass up 17-18 psi?
im also using a GE vacuum manifold and i have the skinny vacuum line from the controller tapped on that... would that be a problem?
Re: (TurboDANDEE)
dandee,
with a 40mm wastegate and a 12psi spring I would hit 23 psi at the 12 oclock position. I had my gain setting on full sharp. I noticed that as you go to mild the boost declines. I am wondering if the bigger wastegate you are using is limiting your boost. donno.
Someone mentioned about an external pressure source.. I am pretty sure that it can also be done on the greddy profec b as well. I haven't tried.. but the concept is the same. I may be doing a co2 setup with my innovative boost controler.
Re: (GSRev)
Alex, does your boost creep or "bounce around" when u have the gain on sharp? i think i tried that once and my boost was unstable ill try again tomorrow, before i head to the track...
Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">just a note, you can use co2 with any boost controller...</TD></TR></TABLE>
Just out of curiosity, how much pressure do you use for the CO2 system to the boost controller?
