low oil pressure at idle
My oil pressure is like 10psi at idle. The pressure line is teed from the oil sender line. I have a H224. I'm pretty sure that it too low. I have a tiny oil leak coming from my oil pan but I don't that is the reason for the low pressure. What else could be wrong?
if you are measuring after the T and at the end of a -3AN line, it will be about 10psi at idle. otherwise, need to check before the T at the stock oil sender location or check there is no small plug in the line,
i have about 15psi after hard runs
20psi usually
on a built single cam....
i think your fine, as long as the pressure increases as you drive and doesnt drop to 10psi when your at like 6 grand then your ok....
Modified by pornstarSR at 8:08 PM 10/19/2003
20psi usually
Excusetobooost
Jun 9, 2020 01:19 PM
TeamSeanFTW
Mar 15, 2011 06:41 PM
AsSanitySlipsAway
12
Aug 27, 2006 09:55 AM
