does my oil pressure and vacuum look ok?
i'm getting around 37-50 when i start up my car. that's when the car is COLD.
i havn't let it warm up yet since i'm still checking for oil leaks.
as for vacuum, i get 20 at idle.
TSPeed Factory
Re: does my oil pressure and vacuum look ok? (1.8)
not sure about oil pressure but the vacuum seems to be about right. my motor idles at 20 and sometimes dip to 25.
Cold oil pressure at idle should be around 60-65 psi on non-vtec motors
My vacuum at idle is around 22-25, which seems consistant with others.
Hot oil pressure at idle is around 18-20 psi.
Where are you getting the reading from?
AsSanitySlipsAway
12
08-27-2006 09:55 AM
