Low Boost
Old Jul 27, 2003 | 05:05 PM
Fatty_1775's Avatar
Default Low Boost
When I floor it, my boost gauge shows that i am boosting 3 or 4 psi. My deltagate is a 7-9 psi spring. What can cause low boost?
Old Jul 27, 2003 | 05:32 PM
Accord94DX's Avatar
Default Re: Low Boost (Autobot_Killer)
boost leak!! check your piping
Old Jul 27, 2003 | 05:40 PM
Fatty_1775's Avatar
Default Re: Low Boost (Accord94DX)
what do you do to check for leaks? thanks.
Old Jul 27, 2003 | 06:23 PM
Dengar's Avatar
Check all the connections on your charge piping. If they are all tight check the vacumn tube that goes to your boost gauge. If it is kinked it could give you a lower reading than what you are actually boosting. When I put my turbo on, my piping was really loose. My gauge read 2 psi and then at one point 0.
Old Jul 27, 2003 | 06:37 PM
Fatty_1775's Avatar
Default Re: Low Boost (Dengar)
Well, right now, on my boost gauge, shows -20 at idle. Does this sound right? My friend's shows the same at idle and when he boosts, it shows 5 psi, which is what his spring is at.
Old Jul 28, 2003 | 06:15 PM
InTeGrA B18b1's Avatar
probaly leak through your intercooler. same thing happen to me but my 7 psi spring went to 5 psi. then i turned the boost up with a boost controller
kabaroo
Jul 18, 2004 03:27 PM
mattcalica
Jan 17, 2004 02:49 PM
arjusmc
Sep 12, 2003 05:22 AM
fire7882
Oct 17, 2002 04:27 PM
1.8EG-T
Jan 24, 2002 12:36 PM
