Losing Pressure?
i don't know I am losing air when i boost..
i checked all the pipes, it's all fine i am thinking of my BOV it sounds like coming out frm the bov but it doen't happen all the time it usually happens when i am in second or third gear... do i need to adjust the bov?? |
Re: Losing Pressure? (xbird)
what car?
intercooler? boost controller? when does it lose boost?.....eg. 5000 rpm how much boost does it lose? You might want to get a boost controller and hook it up from an intake manifold source and then to the actuator of the turbo. You can make a boost controller, or buy one new for around $70 and up. Oh yeah, If you don't have a boost gauge (I assume you do) get one. |
Re: Losing Pressure? (5thgen)
its' a honda civic ex with greddy kit
no intercooler no boost controller just running 5.5 lbs boost i think it runs at around 3 to 4 lbs boost whenever it starts boosting it's only 70 bucks boost controller???? it thought it cots like around few hundreds bucks.... what brand?? is a manual boost controller make a difference than te electronics?? thanks |
TTT
turbo xs has manual boost controllers (summitracing carries them). You can buy one of those or make one too ( http://www.c-speedracing.com ). It's basically a spring and a ball-bearing that holds pressure til' you hit a certain amount of boost, thus opening it up. They can be as good as electronic boost controllers in a sense that you can adjust your boost level and keep the boost level until redline. They are not, however, adjustable by a touch of a button inside the car. That and most EBCs have more features than just keeping a eye on boost.
I had the same situation you did with the greddy turbo/intercooler. Hooked up the boost controller sourced at the intake manifold, then to the turbo's wastegate actuator and my problem was gone. Good luck http://images.zeroforum.com/smile/emthup.gif |
