looking to upgrade. need advice
Old May 3, 2009 | 05:11 PM
TegraGSXR's Avatar
Default looking to upgrade. need advice
i have a stock sleeve b18b je piston eagle rods block gaurd and am running a t3-t4 .63ar. drag manifold. my question is im lookin to get into a 60-1 70ar. i put down 344whp pump gas at 17psi. is it worth the upgraded turbo with the same set-up but with a retune? what is a save psi to run with that set-up? thanks for any advice in advace.
Old May 3, 2009 | 05:50 PM
Ls_dx's Avatar
Default Re: looking to upgrade. need advice
with a conservative tune and some good gas I run 18LB at the track with my B16 stock sleeve... Im gonna do 23ish this year and see what she will do
Old May 4, 2009 | 08:56 AM
TegraGSXR's Avatar
what is your set up?
Old May 4, 2009 | 07:24 PM
turbo97coupe's Avatar
what T3/t4 do you have ? you just said .63 . is it a 50/57/60 trim what lol than we can tell you if a 60-1 would be worth it, also if it helps you at all my friend is making 430 off a 60-1 on his B16 on 93 oct. pump
Old May 5, 2009 | 08:55 AM
TegraGSXR's Avatar
its a 57trim now and i beleive the 60-1 is a 63trim
Old May 5, 2009 | 09:17 AM
TheShodan's Avatar
Moderator
so from 50lbs/min to about 60lbs/min. As long you get the 60-1 that has a larger EXHAUST wheel, like a p-trim or stage 5 (just saying you have a .XXA/R doesn't mean anything) you'll exceed your goal MUCH more than with the standard stage III that comes with the 60-1 T04S. your 57 trim and standard 60-1 use the same exhaust wheel. that could hold you back a bit.
Old May 6, 2009 | 09:21 AM
TegraGSXR's Avatar
ok. thank you for your imput
turbosol94
Jan 14, 2009 06:20 PM
Samuels
Nov 7, 2006 04:34 PM
turbotime
Nov 6, 2006 07:52 AM
juggernaut
Apr 6, 2004 02:53 PM
