loads of smoke CRX turbo
anyone got any tips for making my engine less smokey? It is a 1.6 CRX with turbo conversion, on idle it is poring out white, greyish smoke. Fuel PSI is at about 45PSI and 390cc injectors are in being controlled by SAFC set to about -30% its smells to rich thou and cuts out on idle if i set the SAFC any lower. Any of you guys got smokey engines when you started up your turboed car? It only seems to have happened since i put the injectors in also
thanks
thanks
New User
Re: loads of smoke CRX turbo (djnikko)
You are running rich, or more to the point, super-rich.
Are you sure you have the right injectors? peak and hold? the % on the safc seems OK, but your fuel pressure should be lower, like 40 psi or so.
Get a wideband on it and do some real tuning.
Randy
Randy
