a little rough
Old May 29, 2006 | 03:39 PM
playahwitgame's Avatar
Default a little rough
i just installed my 450cc injectors with my obd1 p72 and honata basemap on my gsr. now it started up(thought it wouldnt), but it did. idles fine, not fluctuating or anyting
bun runs really rough
like the engine is shaking liek ****
now i know its a basemap, not tuned, is this how its supposed to be, let me know, and i havent driven it yet, so the computer isnt programed. respond asap. thanks
Old May 29, 2006 | 04:02 PM
nonvtecD's Avatar
whered you get the basemap? Does it run ok out of boost? I've never had a basemap make the car run as bad as you're describing.
Old May 29, 2006 | 05:25 PM
Default Re: (nonvtecD)
well it started runiing clean no check engine, now i got a check engine. the hondata box is blinking and it wont go past 4k, sometings wrong!!
edit: the hondata cable that gopes to the ecu was getting pinched. i never cut an opening for it. i read thta if its flashing, the prom was put in the wrong way. so i opened up the ecu, at the same time the CEL went away, i cut a slit for the cable, tna dno more cel. yess!!! turbo goes on tomorrow
Modified by playahwitgame at 6:59 PM 5/29/2006
turbo sol
Apr 13, 2009 10:14 PM
mrbsponge
Apr 15, 2006 09:08 PM
boostedcivichatchbacksi
Jun 6, 2004 10:58 AM
VisualAutoMotoring
Jul 28, 2003 10:47 AM
Chiovnidca
May 25, 2003 11:01 AM
