crank???
Re: crank??? (hb_racer)
yes you can it will take a b18c crank and a b16a piston ans a custom piston beacuse you have to move the wrist pin on it up 3 mm this is a great idea for a sleeper good luck it can be done and boy is it fun
stocker kits are really pretty easy to do. the only problem is the rod ratios. get to low and you'll run into problems. In most cases buying a bigger engine is cheaper.
typical block prices;
b18a 600
b18c 1100
b20 850
just remember if you decide to build something do it right the first time and save yourself a lot of cash.
b18a 600
b18c 1100
b20 850
TurboCrime
11-27-2006 02:49 PM
