lightened flywheels with turbo setups
Old Sep 5, 2007 | 01:18 PM
cfwthb_94's Avatar
Default lightened flywheels with turbo setups
Is there a benefit to having a lightened flighwheel in a turbo car? And effect on spool up characteristics?
Old Sep 5, 2007 | 04:38 PM
hotimportcrx's Avatar
Default Re: lightened flywheels with turbo setups (cfwthb_94)
Lighter the Flywheel/Crank Pulley/ Crank = The faster you rev= The faster you spool.
Old Sep 5, 2007 | 04:43 PM
Schister66's Avatar
Man U FTW
Spool is all about load...if your engine revs faster with less load then its going to take more RPM to spool the turbo. It isn't necessarily going to spool faster or slower, but it will change the RPM at which the turbo spools.
I have an 11lb flywheel on my turbo GSR and it still spools fast...3800rpm full boost on my GT3255b
Old Sep 5, 2007 | 04:54 PM
Default Re: (Schister66)
That is 100 percent true, but ultimately the faster you can rev is the faster you can build load allowing a faster spool.
Old Sep 5, 2007 | 07:29 PM
redzcstandardhatch's Avatar
something different
Default Re: (hotimportcrx)
lightweight FW's can make it difficult to launch for some people.. it really depends on your preference
SeDA(9)n
Nov 3, 2008 11:32 PM
HYREV2NR
Sep 7, 2003 11:35 AM
pkripper94
Apr 20, 2003 12:38 PM
Mr. Softee
Nov 5, 2002 04:25 PM
Excelerate
Apr 9, 2002 02:21 PM
