Lean Bogging
Old Aug 7, 2010 | 08:33 AM
Dubs13's Avatar
Default Lean Bogging
What would cause my ride to lean bog? My entire ignition has been changed so I know it's not spark related. When driving at constant speeds or accelerating under light throttle, the car will bog repeatedly and the wideband will show the AFR going lean, normal, lean, normal. Every time it bogs the wideband shows lean.
My assumption is that this is fuel related but what component of the fuel system is most likely to cause such a symptom? Sticky injectors? Clogged fuel line? Bad fuel pump? I know it's not the fuel filter cause I changed it and it did nothing.
Old Aug 7, 2010 | 09:20 AM
94GSRMR's Avatar
Default Re: Lean Bogging
vacuum leaks can cause a lean condtion..
Old Aug 7, 2010 | 09:30 AM
portenio78's Avatar
I got the same thing going on. Check out my thread
https://honda-tech.com/forums/drag-racing-36/completely-stumped-problem-500-whp-del-sol-2809840/
I have replaced a bunch of stuff and it still has the same problem. Guess I gotta keep at it.
Old Aug 7, 2010 | 10:31 AM
Dubs13's Avatar
I redid all of my vacuum lines but I think, just maybe that the little vacuum line going to my boost gauge might be the culprit cause it's a pretty halfass job. Mind you I'm still pretty sure it's fuel related.
https://honda-tech.com/forums/showthread.php?t=2809840
What have you changed so far? Too lazy to read it all, lol.
Old Aug 7, 2010 | 10:41 AM
94GSRMR's Avatar
re do that vacuum, your car maybe suckn in unmeasured air
Old Aug 7, 2010 | 03:13 PM
Dubs13's Avatar
Another thing I forgot to mention is that my AFRs all all over the place when driving. They continually go leaner, richer, leaner, richer. When it bogs it goes really lean. I think this sounds like a stuck injector or something no? Must be something injector related cause as far as I know fuel pumps usually just go don't they?
Old Aug 7, 2010 | 04:48 PM
94GSRMR's Avatar
maybe a relay?
Old Aug 8, 2010 | 09:43 AM
bigD's Avatar
Is the car tuned? Is it in open or closed loop? More information on your setup would help. If its in closed loop it sounds like the closed loop corrections needs to adjusted
Old Aug 8, 2010 | 10:18 AM
Dubs13's Avatar
It's a B18B, stock internals, .50 a/r t3/t4, 7psi, dynotuned on hondata s200 (old setup). I was reading in other threads about corrupt calibration files, I wonder if this could be the case in my case. Cause not only does it lean bog but it runs rich at idle, very rich when you give it anything more than 20% throttle in gear. It wasn't like that when I first got it tuned...
I was already planning on getting it retuned with ECTune by another well known tuner in my area but I want to make sure my car doesn't have any mechanical problems before I bring it to be retuned.
Old Aug 11, 2010 | 02:42 PM
Dubs13's Avatar
Another thing to mention is that when I take the plug wires out of the engine one by one at idle, the idle doesn't change when I take the 3rd cylinder wire off. That and I tried putting new plugs in and letting it idle and 3 of them were black and one had practically nothing on it. Is this an injector or a blown cylinder?
Old Aug 11, 2010 | 02:52 PM
"NastIE Garage"'s Avatar
Do a leak down, maybe bent valves in that cylinder
Old Aug 11, 2010 | 03:02 PM
Dubs13's Avatar
My mechanic just did a valve adjustment on the engine last week. Wouldn't it have been obvious at the point in one of the valves were bent?
Sammyloski
Jun 24, 2009 05:14 PM
juniestyle
Feb 26, 2007 07:34 PM
therealPROJEKTEG
Oct 25, 2005 02:19 AM
peacexisxfree
Mar 14, 2005 07:51 PM
Shakes
Aug 25, 2004 07:05 PM
