Leaky Turbo
Old Aug 8, 2006 | 02:07 AM
mrchris1979's Avatar
Modified by mrchris1979 at 12:26 PM 1/9/2007
Old Aug 8, 2006 | 05:47 AM
bluemax189's Avatar
Default Re: Leaky Turbo (mrchris1979)
yeah, turbo is kind of sitting low. the oil might just be backing up. what manifold are you using?
Old Aug 8, 2006 | 06:07 AM
mike1114's Avatar
Default Re: Leaky Turbo (bluemax189)
Holy low exhaust batman!!
Good luck driving that on the road. Your in Colorado right? I can't imagine the roads there being all that good with mountians and ice to freeze/crack/pothole the road.
man, your gonna bash the **** out of your exhaust on the first day.
Maybe raise your car up some!!
Goood luck on the leaky turbo, hope you pinpoint the problem.
Old Aug 8, 2006 | 09:22 AM
playahwitgame's Avatar
Default Re: Leaky Turbo (mike1114)
is that a 90 degree from home depot in the plumbing section??? if it is, take it off. the hole is way too small. i had the same thing on before the install was done and fired it up to see how it was doing. well it sucked. so it took a month to find the right parts and fabricate a new oil return. what i suggest you do if u still wanna use that same fitting is to take it off, and drill it out some more. if its the same 1 i have, there is extra metal that can easily be taken off. keep us informed
Old Aug 9, 2006 | 07:41 AM
like i said, if u have no other choice then to use the fitting you using now, take it off and drill it out a bit. there is excess metal in there that can be taken out and will make it a bit more free flowing.i had the same fitting.
b00st4life
Oct 22, 2014 11:25 AM
Hondasaurs
Aug 1, 2002 06:33 AM
TurBoXBirD16
Jul 13, 2002 07:48 AM
