Turbo Install?
Old Jul 31, 2002 | 10:40 PM
Hondasaurs's Avatar
Default Turbo Install?
I just installed a TD-05 turbo on my CRX. The turbo is dumping oil into the exhaust. What is causing this and what can I do to fix it?
Old Jul 31, 2002 | 11:06 PM
TheIntegraGuy's Avatar
Default Re: Turbo Install? (ZC_CRX)
can you give us a little more information about the turbo....How long you've had it..etc...it doesnt look so good..
Old Jul 31, 2002 | 11:08 PM
PrecisionH23a's Avatar
i hope its not the oil seal...
Old Jul 31, 2002 | 11:20 PM
Trac226's Avatar
Default Re: Turbo Install? (GudeH23a)
Sounds like the oil seals if the oil is actually in the exhaust.
Old Jul 31, 2002 | 11:31 PM
inspyral's Avatar
Default Re: Turbo Install? (Trac226)
time for a rebuild, or a new turbo...
Old Aug 1, 2002 | 06:07 AM
Hondasaurs's Avatar
Default Re: Turbo Install? (J-MiGiRL702)
I got the turbo off of my friend. It came off of an 87 Mitsubishi Starion. I looks like its in reallly good shape. It has not been used in a few years, its been laying around in the grage. But it did come off of one of his parts cars. Maybe this is the reason it was a parts car.
Old Aug 1, 2002 | 06:16 AM
Hondasaurs's Avatar
Another question: Turbos are a new to me so here is my question, On the turbo itself you have an oil inlet and outlet. On this turbo (Mitsubishsi TD-05) the lagre bent pipe, which is held on with two bolts, is this the oil return? Also, does it matter for the anti-freeze lines which one goes in and which one returns? I'm just trying to trouble shoot this problem. I have another one of these turbos too. I'll probably swap them out today and see if this fixes the problem so I can drive my car.
Does any know any other web sites like http://www.homemadeturbo.com where I can get information on turbo install procedures such as installing the boost gauge.
Thanks so much for your time and help.
Old Aug 1, 2002 | 06:25 AM
IHaveTurbos's Avatar
On the water cooled Mitsu turbo's it doesn't matter which way the water flows through it. I can teel you right now from expericence that the oil seal on the Turbo is bad and time to rebuild or replace.
If you do opt to rebuild contact Geary @ Turbocity.com he usally has them instock for a really good price. Tell him Tim from Speed-Factor sent you.
Old Aug 1, 2002 | 06:33 AM
Hondasaurs's Avatar
Default Re: Turbo Install? (Hyundai4G63T)
Thanks so much for the info, I really appreciate it.
EKris
Jul 22, 2008 02:09 PM
nicktagz
Sep 10, 2006 07:38 PM
silverEH2
Jan 3, 2003 05:08 AM
