Leaky engine!
Originally i thought I had a leak coming from my oil pan. Refer to this thread. https://honda-tech.com/forums/forced-induction-16/oil-pan-problems-2777526/
Well after changing the oil pan gasket twice I am still leaking. The leak was always on the tranny side. I noticed oil gathering on the bottom of the flywheel today. So now I'm thinking it's a rear main seal leak.
I've never pulled the tranny, so I would like to ask a question.
Are there any other seals that I should replace while I'm in there? Thanks.
it should be your rear main seal, you will have to remove your tranny and flywheel to change it
also use a good RTV sealant on the seal holder, it is bolted on the block
mdrouillard1983
Mar 30, 2015 08:03 PM
Dat_One_Si
Feb 13, 2006 06:25 PM
