Leaking coolant from head.....headgasket, right?
Well, I think I may have blown my headgasket.
I'm leaking a little coolant from the front corner by cyl. 4. Enough to leak onto the floor.
Compression is fine 200 across, and theres no oil in my coolant.
What'd you think, minor HG blowout?
Re: Leaking coolant from head.....headgasket, right? (00SilverLS)
When i blew my HG my compression #'s were fine.
Do a leak down, id ur overflow tank rising?
If ur HG is blown, there really arn't degrees of how blown it is. It is or it isn't, especially on a boosted motor.
make sure it isn't coming from one of the coolant lines coming from the head. Check the simple stuff first.
Re: Leaking coolant from head.....headgasket, right? (Type-GS-R-Turbo)
Good thinking.....i'll check first thing in the morning
overflow thank was actually very low....since a bunch leaked out
also check for coolant on the oil cap (looks like mayonaise) or oil drops in the radiator or overflow tank...
that must be a huge relief!! So your car has been running okay since going tubo...its been a year and half now right?
Re: Leaking coolant from head.....headgasket, right? (MiraiZ)
HUGE relief. yeah, no problems yets. no problems w/ mf2. now hondata is going good as well (knock on wood)
yeah...I think with a good stand alone, you could be at 260whp or more...getting rid of the MF2 was the best thing I ever did.....
hybridb18
08-06-2003 09:00 PM
