Blown headgasket...
Old Nov 13, 2002 | 06:17 PM
PrecisionH23a's Avatar
Default Blown headgasket...
Yes, i did an extensive search and basically everything points towards a blown headgasket. A friend of mine has a turbocharged Si and is having problems with his coolant dumping into his reservoir. We replaced the radiator cap with a new one, flushed the system, and it remains dumping coolant into the overflow tank. In the radiator you can see there is a thin layer of oil and small oil bubbles in the coolant, however; there is no mixing of coolant in the oil. The oil looks pure, no milky substance present. When we let the car heat up without the cap on, i noticed small tiny bubbles rising to the top of the coolant, another sign of a blown headgaket. A compression test yielded: 165-163-175-162 on 9:1 compression. So his question is, how long can he safely drive this car without doing extensive damage to the motor? He wants to put it off for like 2 weeks so he can do this during thanksgiving holidays.
Old Nov 13, 2002 | 06:51 PM
shadowdawn's Avatar
Default Re: Blown headgasket... (GudeH23a)
Honestly he should be ok, just NO boosting whatsoever, drive like grandpa mosses for those 2 weeks, and check oil/coolant regularly, and for excessive smoking from the tailpipe....
Old Nov 13, 2002 | 06:53 PM
Default Re: Blown headgasket... (shadowdawn)
You know ive never had luck with compression tests, on his car its reading perfect everything is pointing towards a blown headgasket. Why is this?
Old Nov 13, 2002 | 06:58 PM
E Swift's Avatar
Just because you have good compression, doesn't mean you don't have a blown headgasket.
Old Nov 13, 2002 | 07:01 PM
Default Re: Blown headgasket... (E Swift)
Ive realized that. Ive done 3 compression tests on different cars and ive gotten good readings on all 3. But once the head was yanked.... well it was a complete different story from there. I think im ditching compression tests from now on, time to search up the "cylinder leak down test" those are way more accurate...
[Modified by GudeH23a, 11:02 PM 11/13/2002]
Old Nov 13, 2002 | 07:04 PM
BoostedD15B7's Avatar
GUDEH23...
My motor was doing that same thing. Compression check was good and did everything you said you guys tried. I was left with no options but to change the headgasket. When i took it off i couldnt see anywhere that looked blown or appeared to be leaking, but put on the new gasket and she has been fine ever since.
Old Nov 13, 2002 | 07:06 PM
Default Re: Blown headgasket... (BoostedD15B7)
You know i have YET to see a bad headgasket... does anyone have pictures of a blown one?
Old Nov 13, 2002 | 08:20 PM
whagkangmakulet's Avatar
I had the same problem on my Si. I'm almost done! I'm putting an ARP head bolt this time, plus converting to OBD1 at the same time
Old Nov 13, 2002 | 08:35 PM
DeeJay's Avatar
New User
Before you go ripping the headgasket out retorque the head. i bet you the head is loose on the block.
Old Nov 13, 2002 | 10:32 PM
Default Re: Blown headgasket... (DeeJay)
Yes, that is also an option to the matter. He used ARP head studs and says he did the proper 3 stage torque as well as the molylube. I havnt heard of ARP bolts backing out...
Old Nov 14, 2002 | 06:38 AM
1.8T_EG's Avatar
http://www.geocities.com/dsmgrrrl/FAQs/leakdown.htm
Old Nov 14, 2002 | 08:05 AM
BoOsTeD_eK's Avatar
Default Re: Blown headgasket... (1.8T_EG)
I have a brand new cometic HP headgasket for the vtec head...$85 shipped if you want it.
Old Nov 14, 2002 | 10:16 AM
riceburnah's Avatar
I just blew my headgasket on my ls huge white clouds come out of the exhaust and the engine bay everytime I start her up it sux.
H22AJSPEC
May 23, 2012 12:49 PM
b00sted4dr
Oct 12, 2006 10:19 PM
bretx0r
Jul 17, 2005 10:39 PM
limpy
Dec 9, 2004 10:11 AM
hybridb18
Aug 6, 2003 09:00 PM
