leaking after turbo install
Old Oct 16, 2006 | 06:45 AM
reed857's Avatar
Default leaking after turbo install
hey just put a new turbo in and thought that I had everything running smooth (after a **** tone of work and a call to mase) but then I got up this morning to find a puddle of oil. this is where its coming from any ideas would be great sont have the much experience with earl and his fittings.
Old Oct 16, 2006 | 07:28 AM
92HB_HB's Avatar
Default Re: leaking after turbo install (reed857)
LOOKS like your problem lies /w your turbo seals.. just look at the CHRA and turbine housing.. I see oil seeping out..
Old Oct 16, 2006 | 09:56 AM
reed857's Avatar
Default Re: leaking after turbo install (92HB_HB)
I actually didnt noticed that until I put the pic up it seems like they are leaking alittle too. would haveing a pinched oil drian line do that??
Old Oct 16, 2006 | 10:59 AM
Boilermaker1's Avatar
I also see oil at the top end of the AN fitting where it meets the 45. Check and see if thats tight and sealed. If the tapers don't snug up, it'll leak in the joint because the shoulders aren't tight. Check the seals and see if its just dripping down.
Old Oct 16, 2006 | 11:23 AM
reed857's Avatar
Default Re: (Boilermaker1)
well got it fixed. this thing wsa all my fault I losened it to get the dp in tight and I guess I forgot to tighten it. thanks for the help. Jon
reed857
10
Oct 16, 2006 11:23 AM
itsJDMyo
Jun 24, 2006 11:10 PM
Blkteg97
Nov 16, 2004 08:04 AM
OKSolSi
May 16, 2002 08:52 PM
