Is this leak normal? I heard it was!
Old Mar 7, 2004 | 06:14 AM
SpoolnG2's Avatar
Default Is this leak normal? I heard it was!
Got a question. I just put my motor back together..its got 70 miles on it now and is N/A. I used a stock honda gasket with copper spray and dowel pins on both sides and torqued the head in sequence how your supposed to. There is the slightest bit of oil that kinda sits right by the passenger side front where the block meets the head. Ever since i've built this motor (couple years ago) i've had the same problem. I've used oem headgaskets, cometic, copperspray, no copperspray. Someone told me this is a normal spot for hondas to do this. Is this ok? is it just that the block possibly isnt perfectly flat? I mean the car runs fine and everything...what do u think?
Old Mar 7, 2004 | 07:32 AM
earl's Avatar
Default Re: Is this leak normal? I heard it was! (SpoolnG2)
It is not a head gasket leak and it is not normal. It comes from either the vtec selenoid, the valve cover or the distributor gasket. The oil just winds up by the head.
Old Mar 7, 2004 | 07:40 AM
vtecCJ's Avatar
Earl is right. If anything is going to leak where the head meets the block is coolant from high turbo boost. The oil is coming from up higher.
Old Mar 7, 2004 | 06:09 PM
SpoolnG2's Avatar
Default Re: (vtecCJ)
i guess i'll have to take a look at the vtec selenoid...and the distributor. Your right though, if it came from the block it would be coolant. Anyone else ever have this problem?
Old Mar 7, 2004 | 06:11 PM
Jared's Avatar
Default Re: (SpoolnG2)
I'm 99% sure its the vtec solenoid, back side cam plug, dist oring, or vc gasket.
Old Mar 7, 2004 | 06:12 PM
Suprdave's Avatar
The Oil Drainback for the Head is right behind that spot too...coincidentally.
Old Mar 7, 2004 | 06:22 PM
IN VTEC's Avatar
Default Re: (Suprdave)
I'm battling the same problem. The first time I put the moro together, it was the other side of the header. The next time I had the head off and on, it moved to the other side of the header.
I hose it off with brake parts cleaner every now and then, hoping it'll magically go away...no so much.
I can't seem to win. Yeesh.
Old Mar 7, 2004 | 06:40 PM
SpoolnG2's Avatar
Default Re: (IN VTEC)
Ok, so i just checked all around the Distributor...vtec selenoid....exhaust cam ( i have a aftermarket plug there)....and i dont see any oil coming down the side of the head or anything. So i guess it is the Oil drainback? Is this fixable? why does it happen? what exactly is happening? does anyone have pictures of a head upside down to show me exactly where this is and whats happening?
Old Mar 7, 2004 | 07:31 PM
earl's Avatar
Replace the valve cover gasket and use HondaBond in the corners. It will go away.
Oil return is not under pressure so it would take a big gap to find it's way out of the head gasket.
Old Mar 7, 2004 | 07:33 PM
SpoolnG2's Avatar
Default Re: (earl)
Actually, i just checked my vtec selenoid again, and at the very bottom underneath the actual unit, i put my finger under there and sure enough there was some oil on my finger. Where do i get a new gasket for a 1st gen b16 v-tec unit?
Old Mar 7, 2004 | 07:40 PM
1bar's Avatar
wow i have the same problem!
I just thought if i didnt pay attention to it , then it would go away haha
good to know
Old Mar 7, 2004 | 08:17 PM
gunslinger's Avatar
From: Where thieves get shot in the face,, texas, usa
Its the same part # as a 99-2000 Civic Si
or likewise DOHC vtec engine
turbodailydan
Jul 19, 2009 07:54 PM
scspeed
Apr 18, 2009 01:54 PM
YumYumTurbo
Jun 10, 2007 10:47 AM
DrkGreenAccord
Jul 10, 2005 01:06 AM
servion
May 25, 2004 12:18 PM
