Largest bore for D16
Old Feb 9, 2005 | 06:38 PM
perlmeister8's Avatar
Default Largest bore for D16
Is 78mm bore too large for a turbod d16? B/C that is the largest bore that it will go, would it be beneficial? I understand that if it is blown it will not be able to be rebuilt. This would be for a obviously fully built block, and will be driven at the track and leisurely only. Going for around 300-400 whp
Let me have your opinions...
Modified by perlmeistere81 at 7:49 PM 2/9/2005
Old Feb 9, 2005 | 06:56 PM
Default Re: Largest bore for D16 (perlmeistere81)
bump
Old Feb 9, 2005 | 07:04 PM
Bailhatch's Avatar
18 ******* minutes!!!!!!!!!!!!
Old Feb 9, 2005 | 07:05 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Largest bore for D16 (Bailhatch)
lol
Old Feb 9, 2005 | 07:49 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">18 ******* minutes!!!!!!!!!!!!</TD></TR></TABLE>
Old Feb 9, 2005 | 08:23 PM
Boltz's Avatar
I would probably only take it to 77 if it were me, but what do I know
Old Feb 9, 2005 | 10:37 PM
norcalcrx's Avatar
Default Re: Largest bore for D16 (Boltz)
Hell i would leave it at 75 and run more boost. No need for a 77-78. I would rather have the ability to rebuild a few times.
Old Feb 9, 2005 | 10:54 PM
W O T's Avatar
Default Re: Largest bore for D16 (norcalcrx)
81mm? wouldnt that leave youre sleeves with only a few mm of material?
And you want to run high boost
Imma go measure my block to see how much would be left
Old Feb 9, 2005 | 10:58 PM
W O T's Avatar
Default Re: Largest bore for D16 (W O T)
measuring from the outside of the sleeve Im getting 88mm
Now if you bore the sucker to 81mm, youll have like 3.5mm thick cylinder walls
I dunno how nicely that would work
Old Feb 10, 2005 | 05:29 AM
RStoR's Avatar
Default Re: Largest bore for D16 (rota92)
Just a thought! What piston sizes are readily available without going custom?
Old Feb 10, 2005 | 06:39 AM
Muckman's Avatar
Moderator in Chief
If your going to resleeve go big. But safe big, not crazy big
Old Feb 10, 2005 | 07:43 AM
yellowturbo's Avatar
77mm is the safe way to go... but I dont know if you will see a big difference ?
I dont know if someone did it and could help you ?
Old Feb 10, 2005 | 09:58 AM
W O T's Avatar
Default Re: (yellowturbo)
Yeah man Id just stick stock bore
Most companie carry 75mm/75.25mm/75.5mm on the shelf
Just the basic stock bore, .010 over, .020 over
Old Feb 10, 2005 | 02:39 PM
Default Re: (W O T)
http://cgi.ebay.com/ebaymotors...%3AIT
Here is the auction that brought the question...
per4mance
Feb 28, 2008 12:28 PM
BmfoHPWW
Sep 22, 2007 09:42 AM
CRX 2.0V-T
Feb 8, 2007 06:51 PM
VRD^don
Mar 4, 2005 01:32 PM
lube
21
Oct 13, 2004 10:33 PM
