boost guru's....85.5mm bore too big????
alight u boost guru's...is 85.5 mm bore too big..motor is sleeved....the bore too big to see big amounts of boost..
Re: boost guru's....85.5mm bore too big???? (sohc_Vtec)
The area between the cylinders is gonna be soo ****** thin, I would STRONGLY reccommend against it. . .
Re: boost guru's....85.5mm bore too big???? (m R g S r)
85mm is probably the max i would go unless you got a off centered sleeve setup.
85mm and about 30 pounds will last you but 85.5 asking for issues
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r »</TD></TR><TR><TD CLASS="quote">The area between the cylinders is gonna be soo ****** thin, I would STRONGLY reccommend against it. . . </TD></TR></TABLE>
you really think so..even with it being sleeved..
You ever look at 85.5 block that was sleeved you can easily see how thin it is great for all motor but not for turbo
Re: boost guru's....85.5mm bore too big???? (b18bturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo »</TD></TR><TR><TD CLASS="quote">You ever look at 85.5 block that was sleeved you can easily see how thin it is great for all motor but not for turbo </TD></TR></TABLE>
ture...with that said..anyone one wants a sleeved 85.5mm motor..haha..alright..thanks all..
who sleeved the block if it done by someone it could get resleeved to small bore such as 81mm
Re: boost guru's....85.5mm bore too big???? (Benjithx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Benjithx »</TD></TR><TR><TD CLASS="quote">no room to f'up, I went to 83mm </TD></TR></TABLE>
Re: boost guru's....85.5mm bore too big???? (redturbocivic)
The main problem with being that big is that there's no headgasket left between the cyls. You're more likely to blow a headgasket than crack a sleeve.
Re: boost guru's....85.5mm bore too big???? (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">The main problem with being that big is that there's no headgasket left between the cyls. You're more likely to blow a headgasket than crack a sleeve.</TD></TR></TABLE>
Re: boost guru's....85.5mm bore too big???? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">Dont forget about stroke if you want more displacement. </TD></TR></TABLE>
stroke..??wouldnt stock gsr stroke be good enough for boost..
Re: boost guru's....85.5mm bore too big???? (jdm_whore)
We had 85.5MM on a friends B16 street car. As tony1 mentioned it wouldn't hold onto a headgasket worth a damn. It's OK if you buy a used block like that, but he insisted how awesome his 1.8L B16 turbo car was gonna run, and had his new B16 block sleeved to 85.5MM outright.
Moderator in Chief
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_whore »</TD></TR><TR><TD CLASS="quote">stroke..??wouldnt stock gsr stroke be good enough for boost.. </TD></TR></TABLE>
What exactly dont you understand? Try to stay with me, you can increase the stroke if you want more discplacement and you cant bore any further.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r »</TD></TR><TR><TD CLASS="quote">This is like an 85.3mm bore. . . .that's why I say too thin, look at it....GE sleeved b16 btw....
that is extremely thin
Re: boost guru's....85.5mm bore too big???? (TurboSmart)
Exactly why I sold it and got a b16a sleeved by bensons and stuck with 81.5mm. . .in case of any future problems. . . .
