koyo thick core with t3/t4?
how possible is it to fit a t3/t4 into an integra with a thick core radiator? the manifold i will be using is a southflorida one.
Re: koyo thick core with t3/t4? (g5r)
Do you plan on keeping the stock fans?
You could probably make a lot more space by getting some slim fans and moving them to the front of the radiator, and set them to "push" instead of pull. I did this recently with my civic on the AC condenser, and there is LOTS more room now.
does swapping the positive and negative feed change the direction of the spin on the fan??
I know it worked with a Rover fan i swapped to the front of a radiator a while back.
GRANT!
10-27-2009 03:37 PM
