problem installing today
Old Jul 13, 2004 | 05:03 PM
Ad4mGSR's Avatar
Default problem installing today
so i mount the intercooler, put the charge piping in, then i bolt the turbo up only to find out that it wont fit, my radiator hits the compressor housing, its a t3t4 turbonetics on a revhard manifold, not sure what to do and i am limited on money, any suggestions? i put a new radiator in because mine has a hole in it and put the oem honda fan on the aftermarket radiator, maybe the aftermarket radiator fan will make a difference? i havent tried this yet but id like to get some suggestions on what to do if the fan ends up being the same size. thanks
Old Jul 13, 2004 | 05:05 PM
B18C1CYA's Avatar
Default Re: problem installing today (Ad4mGSR)
on what side do you have the compressor on? ie. drives side or passanger,
Old Jul 13, 2004 | 07:20 PM
Ad4mGSR's Avatar
Default Re: problem installing today (B18C1CYA)
its on the passenger side, if it was on the drivers i would just take the fan out and deal with no AC, but its on the passenger side.
Old Jul 13, 2004 | 07:26 PM
60-1teg's Avatar
Take off the fan on that side and go get you a hadden 10 or 12" fan(o'rileys) and put it on the other side and push the air through. The new fan will only be around 60 bux
you will be like boy there is a lot of room now! That is what i did
Old Jul 13, 2004 | 09:41 PM
Ad4mGSR's Avatar
Default Re: problem installing today (2.0lhatch)
anyone else?
Old Jul 13, 2004 | 10:15 PM
J337_UNIT's Avatar
i run 1 fan.. and its a slim 12" ..my AC sucks ***** but it works when im on the highway pretty well... as for engine temp and what not.. engine temp has remained perfectly normal...but i also ran the fan to a switch so i can turn it on whenever i want.. usually i just let it run all the time
slimsclub
Mar 30, 2011 05:15 PM
808jdm_profileEG6
Oct 25, 2007 03:34 PM
integraGSR213
Jan 26, 2004 05:34 PM
fastbrakes
Dec 28, 2002 03:52 AM
