knife edge crank + track=bad?
New User
If you have a knife edge crank in your car, is this bad if you want to race on a track. If so, how bad is it for the longevity of the motor? I started out being more into drag racing, and it revs quickly with the little rotational mass there is on the crank. I want to start going out to different tracks like Laguna Seca, Buttonwillow, etc... Since there is less material to splash up the oil in the crank case, will I see problems when reving high for longer periods of time?
Re: knife edge crank + track=bad? (blueG2)
For my car (944), knife edging the crank was suggested for tracking the car. Huntley Racing's pov was that less spash = less foaming and less likely for the pick-up to slurp air/foam and then less likely to spin a bearing. Although, I guess another aspect would be whether it is still balanced - if not, could be detrimental yes? Then again, I'd think it'd be detrimental on the street as well.
Whatever, that's just my reference point on it and I am sure on this board you'll get much more sucinct responses - until then . . .
Re: knife edge crank + track=bad? (phat-S)
Splashing = bad. Foamy oil is a no no.
As long as the crank is balanced after knife-edging, it should be ok.
Check http://www.theoldone.com for info for modding the oil pump for better flow (talks about D16, but probably applies to most engines).
New User
Re: knife edge crank + track=bad? (Crack Monkey)
What if my engine doesn't have oils squirters for the pistons? Don't GSR and Type R engines have oil squirters for the pistons to lubricate them better? Will I see a problem there if I don't have those?
