kink in the oil return
Old May 27, 2005 | 08:28 AM
civicek00's Avatar
Default kink in the oil return
could a little kink in the oil return line be a problem my car'
s not boosting?
Old May 27, 2005 | 08:34 AM
hatchinprogress's Avatar
Default Re: kink in the oil return (civicek00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicek00 &raquo;</TD></TR><TR><TD CLASS="quote">could a little kink in the oil return line be a problem my car'
s not boosting? </TD></TR></TABLE> that little kink can cause you alot of problems.....when i had a kink in my return line, the oil would build up in the line and i was gettin alot of smoke comin out of my exhaust(it could of ruined me turbo seals) just get a rubber hose and trim it down and use that as your return
Old May 27, 2005 | 01:17 PM
civicek00's Avatar
Default Re: kink in the oil return (hatchinprogress)
so will it not boost if there is a kink in the line?
Old May 27, 2005 | 01:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicek00 &raquo;</TD></TR><TR><TD CLASS="quote">so will it not boost if there is a kink in the line?</TD></TR></TABLE> that im not sure.....but it could ruin you turbo
Old May 27, 2005 | 02:15 PM
civicek00's Avatar
what is safe to run on a stock 99 civic hx d16y5
Old May 27, 2005 | 02:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicek00 &raquo;</TD></TR><TR><TD CLASS="quote">what is safe to run on a stock 99 civic hx d16y5</TD></TR></TABLE> what do you mean??? how much boost?? or what kind of return line??
Old May 27, 2005 | 02:27 PM
pv2dickman's Avatar
your turbo can still boost.. but with a kink in the return line.. backpressure will build and oil will come out the seals and a lot of smoke will come out of your exhaust.. you need to fix the return line before driving it again... you can still ruin the seals driving slow
Old May 27, 2005 | 02:28 PM
Default Re: kink in the oil return (pv2dickman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pv2dickman &raquo;</TD></TR><TR><TD CLASS="quote">your turbo can still boost.. but with a kink in the return line.. backpressure will build and oil will come out the seals and a lot of smoke will come out of your exhaust.. you need to fix the return line before driving it again... you can still ruin the seals driving slow</TD></TR></TABLE> what i ment to say
Old May 27, 2005 | 02:54 PM
turbo Si's Avatar
I had that happen to me once. I noticed the kink but didn't think it was an issue at first till I had a load of smoke coming out the exhaust. Once I took the air filter pipe off the turbo inlet is when I noticed the oil build up. Thank god it did not damage the seals, because I was already broke. I went to the hardware store and bought some metal springs, cut one down to size and pushed it through the rubber line and the kink was gone. It beat taking off that manifold again!
Old May 31, 2005 | 09:38 AM
civicek00's Avatar
Default Re: kink in the oil return (turbo Si)
i fixed the kink an now when i drive it it still does not boost and doesnt rev past 4500 could that be a problem with the vacuum? now that its fixed there is a little smoke coming from the turbo itself so what could be the problems?
stackz
Feb 28, 2008 01:49 PM
T9U4ReBgO
Nov 25, 2007 02:44 PM
88crxhfb16
Jun 27, 2005 08:53 AM
B18 CYA
Apr 21, 2004 04:34 PM
D A 9
Jul 27, 2003 05:16 AM
