boost creep issues, tial 40mm WG, OBX ramhorn mani, wont hold steady boost..
Old 05-30-2005, 06:44 PM
Ls1 FD3s's Avatar
Default boost creep issues, tial 40mm WG, OBX ramhorn mani, wont hold steady boost..
I have a .4bar spring in it, which is like 6.4psi. Holds steady in 1st, 2nd, 3rd gear after VTEC it will creep to 8-9psi, 4th gear is real bad, creeps to 10-11-12. Its very consistant with the creeping too, which sucks ***.
Setup:
t3/t4 garret
OBX ramhorm ---this damn thing even tho its a bootleg of full race should not make any difference
Tial 40mm WG with atmospheric side exit
3in downpipe ran open downpipe
My tuner says its the manifold, flows so well it kinda bypasses the WG, a larger WG might do the trick. Also the 3" DP ran open DP is the other issue (no backpressure)
Anyone think if i ran a fulltime 3" exhuast all the out the back with no fart cannon, im talking pure 3" all the way baby. Think that might help reduce the creepage? Anyone else have any ideas/thoughts/comments?
lastly, i might be building an engine, at higher boost levels does this same **** occur? Or not really since the WG doesnt have to work as much?
Old 05-30-2005, 06:45 PM
Who is Mr Robot?
wantboost's Avatar
Default Re: boost creep issues, tial 40mm WG, OBX ramhorn mani, wont hold steady boost.. (Ls1 FD3s)
its the manifold... you could try a larger wg, but im pretty sure it wont help much
Old 05-30-2005, 06:52 PM
non-VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls1 FD3s &raquo;</TD></TR><TR><TD CLASS="quote"> Tial 40mm WG with atmospheric side exit
i dont think your manifold is the problem...........what do you mean by atmospheric side exit? i think you may have your vaccum lines hooked up wrong on the wastegate.
Old 05-30-2005, 06:53 PM
Boostage's Avatar
Default Re: boost creep issues, tial 40mm WG, OBX ramhorn mani, wont hold steady boost.. (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">its the manifold... you could try a larger wg, but im pretty sure it wont help much</TD></TR></TABLE>
how do u figure? the wg placement is central. I love bandwagons.
Old 05-30-2005, 06:56 PM
Who is Mr Robot?
wantboost's Avatar
Default Re: boost creep issues, tial 40mm WG, OBX ramhorn mani, wont hold steady boost.. (Boostage)
lol, this isnt a bandwagon, its physics and its ture with everymani from fullrace to obx, i wasnt referring to the fact that its obx.
The wg is exactly 90* to the exhaust flow, when the exhaust gasses are hauling *** through the mani (technical terms, dont you love it) they dont really want to slow down and turn 90* to be bypassed around the turbine. If the flange was recut and angled at about 45* or less, the exhaust gasses would be more willing to flow through the wg
Old 05-30-2005, 07:29 PM
Ls1 FD3s's Avatar
what Wantboost speaketh makes sense and pretty much was my conclusion too. When VTEC hits it jumps 2-3PSI, aka exhaust gasses bypassing the WG port. At low speeds it holds boost like a champ. Anything above 6500 is risky. At the same time however,,, i have a y-cutout setup for my exhaust. Except i reversed it and have the wing nut cap on the straight through part and the side that spurs off is 2.5" exhaust all the way out. When i have the cutout closed, its a turd, but holds steady boost at 6.5psi or whatever boost level i select with the boost controller. Its on open DP (when i open the cutout) when i get this creep issue badly (sorry if i wasnt more specific on my setup) Thats why i think maybe a fulltime 3" exhaust might help a wee bit.
As for the atmospheric WG dump, some kits (very few) plumb the WG exhaust back into the downpipe, i have mine firing out the side of my front bumper. Wasnt sure if that could be an issue, so i made mention of it...
Old 05-30-2005, 08:02 PM
Who is Mr Robot?
wantboost's Avatar
i know it makes sense... thats why i said it
Old 05-30-2005, 08:03 PM
project dc2's Avatar
ive heard of a lotta problems with tial 40MM's
Old 05-30-2005, 08:14 PM
Ls1 FD3s's Avatar
Default Re: boost creep issues, tial 40mm WG, OBX ramhorn mani, wont hold steady boost.. (project dc2)
What problems&gt;? TOo big per setup? too small per setup? Awkward sizing has this mysterious goemetry that has issues with 1.6-1.8L honda engines? LOL
Old 05-30-2005, 08:17 PM
Who is Mr Robot?
wantboost's Avatar
reqally big valve, plus big diaphram = slow reaction time
Old 05-30-2005, 08:33 PM
On Fire!
Adi Radoncic's Avatar
if you do a search there is a few threads on this already.
The problem is the manifold design and not the wastegate, people are creeping with 38's 40's and 44's.
Old 05-30-2005, 08:45 PM
Ls1 FD3s's Avatar
Default Re: boost creep issues, tial 40mm WG, OBX ramhorn mani, wont hold steady boost.. (newgsr)
has anyone dared to cut the WG tube/flange off and have it re-welded to a 45* angle?
Reduce any creep issues?
Old 05-30-2005, 08:47 PM
Who is Mr Robot?
wantboost's Avatar
jordo ended up having a mani made so he could run two 44mm tials... apparently it worked, it stopped the creep. hes also selling the two tials and the mani, lol
Old 05-30-2005, 09:47 PM
Ls1 FD3s's Avatar
maybe he liked the creep?
Old 05-30-2005, 09:50 PM
Who is Mr Robot?
wantboost's Avatar
no, he spent almost 3k to stop the creep. his mani worked, it doesnt creep anymore
Old 05-30-2005, 09:56 PM
Ls1 FD3s's Avatar
ya i just tracked down that thread, ***** intense. Tall $$ tho. I might try something crazy with setting that WG at a 45* angle.
Will the **** still creep at 18psi? Cuz at that point the WG isnt open all that much as compared to 6.5 PSI., maybe that has an effect on the creep issue? Just a thought, i dont know. lol.
Old 05-31-2005, 12:17 AM
i dunno i got a 38MM on my car no problems. 400 WHP
Old 05-31-2005, 01:29 AM
Ls1 FD3s's Avatar
what manifold? open 3" dp? 3" to 2.5? Has to be some other variables that make it work for you.
Old 05-31-2005, 09:04 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls1 FD3s &raquo;</TD></TR><TR><TD CLASS="quote">what manifold? open 3" dp? 3" to 2.5? Has to be some other variables that make it work for you.</TD></TR></TABLE>
FR style made by me. 3" dp 3" exhaust.
Old 05-31-2005, 09:49 AM
Who is Mr Robot?
wantboost's Avatar
ill be using a 38mm wg on my 500+ whp build. probably go with a mini-me stule mani tho
justYncredible
08-14-2012 09:17 AM
jdmfr3ak
08-11-2006 05:05 AM
greasemonkee
04-26-2006 12:59 PM
the.hamburglar
04-16-2006 01:30 PM
KStuned
12-08-2003 11:52 PM
Quick Reply: boost creep issues, tial 40mm WG, OBX ramhorn mani, wont hold steady boost..
